Anyone see a value to a complete TPI injector swap tech article?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BurbinOR, Jan 22, 2002.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    I swapped injectors on Saturday, took about 30 photos and documented socket sizes, etc. for the job. If there is interest, I'd be glad to write the tech article.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com/>BlazzinOR's Beast Buildup</a>
  2. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Definately would be interested. :)
    Boss
    Pic of my truck Before N' After
    <a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
  3. 82GMC
    82GMC 1/2 ton status
    May 14, 2000
    553
    Seattle Washington
    I whould like to read one to! And you're just the guy to write it, If you ask me!![​IMG]
    I am the hunter Who live's in the darkness, And grows through your fears...... And you are the hunted.
  4. BurbinOR
    5,829
    Oregon
    OK, its worth doing [​IMG]................got it done this morning. Just need to ask Steve how to send it in, and how to handle the pictures.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    This means that you now understand the one thing that I hate the most about TPI. [​IMG] Can you believe how much other stuff has to come apart to get those freakin' injectors out? What were they thinking? [​IMG]
  6. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Yeah changing an EGR valve on one is fun too. I'm glad I dont need it
  7. BurbinOR
    5,829
    Oregon
    Yep, good thing it isn't something you need to do often...............I wouldn't have had to do it but I had a stinkin' feeling I was going to find bad news..........and I did.............I found my engine builder screwed up and put 19 lb injectors in the original build. 19 lb injectors in a 406!!! Talk about pissed.............and he was rather apologetic about it..................I knew something was wrong........the BLM's were up as were the integrator numbers...............the truck ran excellent but I always knew it had more, ya know what I mean? Well, the BLM numbers and Integrator numbers are 128, it runs better than it ever, ever has and I am tickled. My one mistake in this deal was NOT learning up front about TPI, tho I had no time at the time [​IMG]. Ah, well, better late than never, now the only thing I can't do is auto trannies...........and I don't think I'll need to learn them (I hope)...........and a truck that runs better than ever.
    As for EGR, that's about an hour job..............8 T-40 bolts, 4 10mm throttle bolts and you're there.............
    ONE TON</font color=blue> <font color=green>TPI'd</font color=green><font color=red> BEAST<font color=red>
  8. Sandhills Blazer
    Sandhills Blazer Registered Member
    Nov 6, 2001
    45
    South Carolina
    Looking forward to the article. I'm in the process of putting a 1999 Vortec in my 1991 Blazer and using the TBI from the current motor. Will I need to make any changes to the TBI setup. I already have the vortec heads drilled and tapped to use the original manifold. Will your article help with a change over to the TPI on the vortec?
    Herman
    '91K5 - 350, 700R4, NP241, Single 3" with FlowMaster, 32X1150s
  9. BurbinOR
    5,829
    Oregon
    Herman, sorry, but this article will probably do little to help your situation regarding TBI (throttle body).
    That said, if you want to put TPI on your vortec headed motor, YES it will help. All you would need is the new Vortec TPI manifold, and the rest shows the way the injectors/rails/and runners go together. TBI is a somewhat different animal, tho many of the basics are the same.
  10. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    19 lb injectors... ouch... so what size did you upgrade to?
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  11. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    oh yea!!! would love an article on this!
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  12. BurbinOR
    5,829
    Oregon
    Yeah, OUCH is right. Pissed me off..............but the guy made a mistake, I can live with it. Upped them to 24 lb/hr Accel units.............solved the BLM problems I was having, and runs soooooooooooooo much better. I knew something was up............so now I am meeting with the builder to get my $$ back.
    24lbers are plenty large enough for up to 450 hp by the way.
  13. Sandhills Blazer
    Nov 6, 2001
    45
    South Carolina
    Thanks, will I need a new computer and chip for the TPI setup or just the computer and chip that comes from the donor?
    Herman
  14. BurbinOR
    5,829
    Oregon
    The computer from the donor and even maybe the chip from the donor will work, if you're putting in the VSS (vehicle speed sensor) and it doesn't have VATS (vehicle anti theft system). Otherwise you will need a chip with those systems programmed out. The ECM for a Speed Density motor is the 730.............not sure about the MAF computer number.
  15. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    I bet those 8 new brand new inj's set you back just abit Frank.... :0). The wife is pregnant bud! We are in the midst of selling the townhouse so i can have a bigger garage for the K5 Garage...least thats the way i see it...lol. Been down in Parker for the last two weekends...matter o fact leavin in 2 hours....runnin checkpoints with the chalet...will take good pics. Later tatter.
    Azblazer
    1979 K5 350 TBI
    1976 K5 Chalet
    If it ain't got arizona pinstriping.....you ain't wheelin the pee outa her!
  16. BurbinOR
    5,829
    Oregon
