anyone seen Dr. Chin
Discussion in 'The Garage' started by 69K5, Dec 15, 2003.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i was looking throug disc brake stuff and came across this on his website. says he used 83 calipers. will thgese work??
    <font color="green"> Brakes: Factory front disc rotors and calipers with semi-metallic pads, 1983 Cadillac Eldorado rear brake calipers with semi-metallic pads, modified front rotors on rear axle, custom rear parking brake cables, modified 1978 Cadillac Seville brake proportioning valve, 1978 Cadillac Seville brake master cylinder, modified 1987 Buick Regal 4-door vacuum power brake booster, modified brake actuating linkage. Click here for the how-to article on the rear disc installation.
    </font>
    did these have the p brakes?? the one on an eldorado i saw today had it but it was an 84. i thought it wouldnt work so i didnt get it.
    thanks
    69k5
  2. Grim-Reaper
    7,385
    Atlanta
    Yeah they had parking brake and it's a better designe then the 77's. Problem is they will NOT fit over a stock GM front vented rotor with stock pads. You have two choices.. 1. Machine the pads down and loose about 50% of the pad.
    2. find a non vented rotor and redrill it to fit the GM truck lug pattern.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Steve did this on half ton axles. I don't remember what he used for rotors /forums/images/graemlins/confused.gif
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    he used the tsm kit. it comes with rotors. it's a bit expensive but almost all there. i do wonder what happen to him.
    ARQ.
  5. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    well i have no way to machine pads and dont think i would want to. and i s also have no way to redo rotors to work. i guess ill just have to keep looking. maybe i can find some 1" thick 8 lug rear axel and this will make more options. did any 8 lug rotor ever come that thin that anyone knows of?
    thanks for all the help
  6. dyeager535
    26,979
    I doubt it. Vented "truck" disks all seem to be over 1" thick.
    Maybe some older unvented stuff will work? Hve to be a big truck, but I've seen some older 8 lug axles with disks, perhaps there are some old applications that used unvented 8 lugs?
    I've seen some Nissan(? foreign whatever it was) that had unvented disks for the front, but they were only about 1/2" thick.
  7. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    1/2 " man thats thin. I have a friend that works at the parts store. i guess i better get him to do something at work.
    anyone else that works at a parts store let me know of you know anything
    thanks
    69k5
  8. Grim-Reaper
    7,385
    Atlanta
    Maybe the new silverado's or H2.
    I'll have to measure the 1/2 ton disc I have and see. The problem is it will still need some machining. They go over the axle on the 1/2 ton like a front wheel drive Disc. I better the 3/4 is the same way.
