anyone sell pre-bent brake lines and trans lines?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Loose Nut, Nov 28, 2005.
  1. Loose Nut
    Loose Nut Banned
    Nov 6, 2005
    445
    Maryland
    I have a 91 gmc jimmy and need to replace all the lines in the truck because there rusted so bad there at the breaking point.
    i can bend the lines myself but would prefer to find some prebent and set up so i can just put them in and be done with it.
    plus its a time saver in my books.
  2. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    LMC has the brake lines but I'm not sure about the trans lines
  3. Loose Nut
    Loose Nut Banned
    Nov 6, 2005
    445
    Maryland
    cool thanks bro. Looked them up and called and they said they have them for 219$. i quess i may just bend them up my self :P
  4. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    in the back of the off road mags there is a few places.
  5. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    DANG! yeah it's not that much time saved for 200 bucks:eek1: I'd just get bending;)
  6. Loose Nut
    Loose Nut Banned
    Nov 6, 2005
    445
    Maryland
    there in the same boat, they either dont offer anything for my truck or there insanly priced.
  7. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    I had a customer order them for a jeep I was building him. By the time I got them all routed I had rebent half of them. Kind of hard to snake a 8ft single line above the crossmembers and around the engine mts etc. Probably worse on a K5 were it runs under the motor mount then hangs a 90* and accross the front crossmember.
  8. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
  9. Loose Nut
    Loose Nut Banned
    Nov 6, 2005
    445
    Maryland
    the kit from LCM is a 8 piece kit. stainless steel to. 219$ for those interested.
  10. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I'll 2nd inlinetube. Great service and support, I have done bussiness with them on a few occations and never had a problem.
  11. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
  12. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I'll third it. Did both of my trucks, front to back in stainless (fuel lines, brake lines, tranny cooler lines, trans modulator lines, etc, etc). Best money I spent. Didn't have to bend or flare, worry about leaks or have a million unions on the truck because the lines at the local parts stores were only 3-4' lengths depending on size (I hate unions if you don't have to use them....just one more chance for a leak).
  13. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I'll forth it. $200 for a full set of pre-bent stainless lines with wire armor. Perfect fit, great company. Way easier than doing it yourself. I've had auto parts store brake line rust through after 2 winters. Brutal. I live right by them, they are great people.
  14. GaBnn3
    GaBnn3 Registered Member
    Jan 2, 2005
    90
    Holyoke, Ma.
    3rd on inline
    I just got the stainless for my Suburban and they fit...mmmm...nearly perfect.
  15. Loose Nut
    Loose Nut Banned
    Nov 6, 2005
    445
    Maryland
    ordered my lines from lcm, stainless steel to, i think was thursday, they were at my door tuesday :P
    cant wait to put them on!
    yea, they were exspensive, but its 15-20 degrees out, i dont really feel like bending metal all day :)
  16. GaBnn3
    Jan 2, 2005
    90
    Holyoke, Ma.
    I agree. Besides, you only want to have to do this once. I noticed gas running down the frame rail when it was running, which was from a rotted fuel line. Upon looking into it, the leaking fuel line was in a bundle with the brake line and vent tube, so I replaced all at once. I got carried away and put a new tank and fuel pump in as well. I didn't see the point in putting the old stuff back in with new lines. I also used POR-15 on the frame and top-coated it with chassis coat black, while the lines were off. I now like to lie under the truck and admire my work. LOL... 4x4 for life!
  17. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
