Anyone swap in a 454
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by smp, Mar 5, 2001.
  1. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    I just picked up a 454 and was wondering about the swap like motor mounts or anything else that i am not thinking of.
    <A target="_blank" HREF=http://WWW.SMP.COLORADOK5.COM>http://WWW.SMP.COLORADOK5.COM</A>
  2. CK5
    May 19, 1999
    21,623
    701
    CO
    Talk to Shawn, he has done this swap, I believe other than larger radiator misc brackets etc it will bolt up to your bellhousing, even your motor mounts.
    Steve
    Mall-Running poseur 4x4 with curb-feelers
  3. SilverJim
    SilverJim 1/2 ton status
    Sep 23, 2000
    105
    Evergreen
    I put a 502 in my 70 Jimmy...everything worked out fine except you need to be careful about what valve covers you use. I put on a 3" body lift before I put the body back on (after the swap had been completed w/o the body) and the valve covers were awfully close to the firewall. I used small block motor mounts...the only thing I have to do now is find headers that fit...the 69-72 4x4 pickup/blazer headers don't fit, they hit the crossmember. I think chevelle headers from about the same time will fit...or at least that's what I've heard. Anybody got any info on that? The front most pipes on either side of the block need to go up and over the others instead of straight down (yeah i know that hardly makes sense)
    1970 GMC Jimmy 502HO/SM465/NP205 doesn't run just yet!
  4. HarryL
    HarryL 1/2 ton status
    Feb 25, 2001
    139
    Layton, UT (20 miles north of SLC)
    Ayup. I bought a 72CST from a fellow in tejas who swapped in a 454 into it. The 454 came out of a 78 3/4t burb. He also swapped in the axles into it. The 454 fills up the whole engine. The truck has a 2" body lift to clear the HEI at the firewall. Headers will not fit, so I'm running brand new manifolds. New 4 core radiator, with an external electric fan on the outside. SB motor mounts. Lots of other stuff I seem to be forgetting. 8" front leafs, shackle flip, stock leafs, 4" blocks in the rear. 38" gumbos. If you have any questions, email me.
    Harry
  5. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Wow! They can do that?
    :D
  6. Clockwork71
    Clockwork71 Registered Member
    Mar 23, 2006
    23
    Waukesha,WI
    the big block swap is pretty simple. you will need a body lift or pound the firewall with a hammer until the valve covers fit, like i did. doug thorly tri-y headers for 73-87 bbc 4wd will fit but you need to grind the frame on the pass. side for one tube. you could swap a 73-87 crossmember and motor mounts and i think most 73-87 headers will fit, but you can use the stock small block cross member and motor mounts(i did).last the fan shroud will need to be trimmed as the accessories are further forward. there may be other things here and there but those are the major things
  7. fordeater
    fordeater 1/2 ton status Premium Member
    Mar 21, 2004
    1,402
    Missoula, Montana
    holy freakin old post
  8. CDA 455
    Jun 2, 2006
    8,598
    43rd State
    :haha: :haha: :haha: :haha: :haha: :haha:
  9. 69TowRig
    69TowRig 1/2 ton status
    Dec 20, 2004
    288
    Raleigh, NC
    If you get the Big Block towers out of a 2wd you can bolt them in and the exhaust will clear properly. There is a "divot" in the BB towers that gets the exhaust to clear properly.
