Anyone swap out a 208 for a 241?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kpanza, Jun 4, 2002.
  1. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Hey guys,
    I am wanting to swap out my old, leaky, probably cracked again 208 for a 241 case. The truck is an '87 and has the mechanical speedo of course. The 241 I am looking at buying also has the mechanical speedo setup (I think it is out of an '89).
    I guess what I am wanting to know is what, if any, modifications am I going to have to do to make the swap happen? Are the 208 and 241 the same in length, so I can avoid driveshaft length changes? Will my present driveshafts hook up to the case, or is the rear slip yoke a different spline count? All of the shift linkages are coming with the 241, so will they all hook right up to my floor shifter just fine?
    Any other things I have missed and you can comment on, I would really appreciate! Hopefully it's a simple matter of dropping one out and bolting the other in, but I know there is always SOMETHING!
  2. kpanza
    Dec 8, 2000
    1,579
    No one's done the swap?
  3. smartpatrol
    smartpatrol Registered Member
    Feb 6, 2002
    86
    Ault CO
    Why not just go for the NP205 swap?
  4. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    2.72:1 low versus the 205s 2:1 low, lighter, the NP 241 bolts right on to the 700r4, and they make a SYE kit for it. Sorry cant help you on the driveshaft part, but I believe they are the same. My dads Burb (89) has the same length d-shaft as my burb with a 208.
    Dan
  5. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Anyway to bolt an NP241 case to an SM465 trans?
  6. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I did the swap (both ways) a month or so ago, just bolt in and go. I would recommend adjusting the shifter linkage when you're done.
    Pete
  7. kpanza
    Dec 8, 2000
    1,579
    Cool, thanks for the replies guys! I think I am gonna go for the 241...and someday also do the SYE with one of High Angle Driveline's CH shafts as well...
    Pcorsmitt - so the driveshafts didn't need to be changed at all? That was my major question, as I have spares and everything and don't want to be having to go down and get them all lengthened or shortened just for the swap! /forums/images/icons/smile.gif
  8. kpanza
    Dec 8, 2000
    1,579
    Cool, thanks for the replies guys! I think I am gonna go for the 241...and someday also do the SYE with one of High Angle Driveline's CV shafts as well...
  9. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    If there are any differences in the output lengths, they are very small--I didn't notice any difference.
    Pete
  10. kpanza
    Dec 8, 2000
    1,579
    Great! That's what I wanted to hear! /forums/images/icons/smile.gif As for the shift linkages, are they the same? O r do I need to get the linkages with the 241 and swap them into my truck and get rid of the 208 linkages?
    Thanks!
  11. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    I left the linkages on the trucks, and disconnected them at the lever on the t-case (took the cotter pin out).
    Pete
  12. kpanza
    Dec 8, 2000
    1,579
    Great, that's what I wanted to hear about the linkages...just leave them in there and hook it back up to the t-case...
    Thanks for your help!
  13. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Isn't the trans case adapter different? My 241 adapter behind my 700 is different than my friends 208 behind a 700. My blazer is an 89 and my friends is an 84. Did they change adapter styles between the years for either case?
  14. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    They changed the adapter to accomodate a different style trans mount, around '85. The actual trans/adapter/t-case interface remained the same though (at least functionally).
    Pete
