Anyone tow with a 8"-10" lift?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DesertDueler, Dec 16, 2001.
  1. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Anyone tow with a 8\"-10\" lift?
    I was thinking of putting a big lift on my burb, but I tow with it. I tow either the Jimmy or the Firebird. Mostly the Firebird, but will tow the Jimmy on anything farther than 2 hour drive. How welll would a burb tow with that big of a lift and either 38s or 40s?
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    Re: Anyone tow with a 8\"-10\" lift?
    So would that be with the same wimpy 1/2 ton axles and stellar 700R-4 that just blew up? [​IMG]
    Consider the size of the drop hitch you'd need and the amount of leverage that would be exerted on it, laterally as well as fornt to back.
    I wouldn't even consider it...just MHO
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  3. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    No I would step up to a 14sf so I can keep my 6 lug, and probably go to a th400 and 205 t-case. My buddy had a 94 sub 1/2 ton with 19" lift and 44s with stock rear axle and solid front axle swap with no problems being a cruiser. Stock tranny to.
  4. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    That and I got the idea from the body shop down the street from work. They use a 2000 F-350 with 10" lift and 40s to tow all the cars to the shop. Big drop hitch and its works fine, but its a 1 ton.
  5. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Check some of the bigger hitch manufacturers, they make receiver hitches for up to a 8" drop. This is the actual hitch, not the part that goes into the receiver, that has the 8" drop.
    1 ton '87 Chevy SWB in the making!
  6. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i tow every now and again. the only thing is to make sure the brakes on the trailer work just slightly better than the ones on the truck... i have problems in the rain when stopping and steering, my front wheel gets light
    Tork DSR
    "look ma, i can make the dog pee white...."
    aol screen name TorkDSR
    <a target="_blank" href=http://www.torkpig.homestead.com>http://www.torkpig.homestead.com</a>
  7. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    Due to the higher CG of the lifted vehicle &amp; the added sidewall flex in the tires, I also recommend a load equalizing hitch (class V) with adjustable drop. It may be overkill if you have an open trailer, but its not much more than a lighter duty one. My hitch is 2" x 2" solid...not hollow as most Reese type hitch adapters are. This setup &amp; it will actually drop the front height of the truck with the rear to help keep it level as tongue weight increases. I have a 34' enclosed Haulmark trailer (13,000GVW) that will hold 2 cars &amp; is way in excess of what you should hall with a pick-up. Without the hitch, the trailer would start to sway &amp; cause the truck to dance around by flexing the tire sidewalls &amp; suspension.... after adding the load equalizers it stays stable even in cross winds. Difference was well worth the $275 investment. Hope this helps.
    Lonnie
  8. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    TOTALLY AGREE!! Those weight distribution systems make ALL of the difference in the world. DEFINATELY woth the $$ IMO.
  9. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    I will get a weight dist. systems. Now for tires, the biggest I can go in radials are 38s in either a ground hawg or a tsl radial, what do you guys recomend?
  10. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    TSL radial
    6in 87' K5 w/ 35" BFG muds.
    305/Sm465/ NP208
    Kn, 4.56's.
    In desperate need of a rebuild.
    Next- Eaton mech locker... Flows.
  11. sinchphoto
    sinchphoto 1/2 ton status
    Mar 7, 2000
    366
    Southern California
    check offroad unlimited they make badd ass towhitches.
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Why not just mount short tires for pulling? That'd be awesome if you were geared low. Imagine having 4.56s or 4.88s and 33" tall tires. That'd be one hard pulling truck!!
    Sure, it'd look gay, but it'd pull harder and be safer IMO.
    Tim
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    I agree!! [​IMG]
    ORU does make some bad ass hitches!! [​IMG]
    They have 4 different drop hitches.
    14" drop, #87014, $325.95.
    16" drop, #87016, $355.95.
    18" drop, #87018, $377.95.
    20" drop, #87020, $412.95.
    I know the prices are outrageous, but when you see the pics of them, they are way cool and beefy!! [​IMG] [​IMG]
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  14. jwduke
    Aug 25, 2001
    721
    Definately TSL radials!
  15. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Radials are overrated, if you go Bais ply you don't have to worry about weak sidewalls.
    IMHO SS SX's fit the bill !
  16. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Yea but I dont think my K5 and my Burb need SXs. Bias suck to tow on.
  17. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    Why not try the Baja Claw 38's, or the Parnelli Jones 38's? They both seem to be not TOO rough for the road, but would still look pretty cool. The Claws are belted, I think, and the PJ's are radials. Besides, then you could give us all a full report on how these tires do on your occasional off road jaunt, since I've never seen a report on either of these tires in the 38 size and after alot of miles. I love spending other people's money.
    Karl
    Temporarily Unemployed Underwear Model
    87 3/4 ton
  18. jwduke
    Aug 25, 2001
    721
    Bear Claws wear like crud on their own, add towing with them, and they will be wore out in 1 trip!
  19. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    and Pj's are like a gadjillion bucks
    -matt
    <font color=purple> "Stuff's only good for 2 things, degreasing engines and killing brain cells"</font color=purple>
    <a target="_blank" href=http://www.geocities.com/shaggyk5>www.geocities.com/shaggyk5</a>
  20. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    I've towed for 12 years with my '88 crewcab dually with 10" lift and 42" Swampers. No problems. My tow is a 28' offshore boat on a triple axle trailer. Total trailer and boat weigh 8500 lbs. Nothing like a dually to tow with. Also, my Suburban has 12" National springs and 39.5" Swampers and tows just fine. I tow a trailer loaded with quads on it, or my sand Jeep. No problems towing! LIFT AWAY!!!! Just be sure to re-gear sufficiently for the weight. My dually is geared at 5.13:1, and the Sub at 4.56:1.
    ken
