Anyone tried Equal- Tire balance powder?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76chevy, Dec 27, 2001.
  1. 76chevy
    76chevy 1/2 ton status
    Aug 16, 2000
    246
    Utah
    Has anyone tried the Equal stuff that you put in your tires to automatically balance them with no weights?
    <font color=red>Spirit of 76</font color=red>
    <a target="_blank" href=http://homepage.mac.com/toddcripps/Menu2.html>homepage</a>
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Hispanic Panic did. it wasn't "equal" but a local tire place had generic "tire balancing compound"he only did the front. he said it worked a lot better than no balancing at all. he wont be back till the beginning of the year he could give more input.
    Sun Desert Offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
    It's all fun and games till someone loses an eye!
  3. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    yes, i tried it.
    on large swampers
    didnt make them round
  4. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    Ive heard it works real well for anything over 39.5s
    79 Jimmy, 5" lift 35 M/T with a 383 puttin out 400hp and 450lb/ft. 4.11s Locked front and back.
  5. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
  6. sinchphoto
    sinchphoto 1/2 ton status
    Mar 7, 2000
    366
    Southern California
    i tried it on some big mickeys. this stuff is designed for 35 &amp; over tires. I get a slight shake when im stopped and hit the gas but once tires are turning"""""""""smooth sailing""""""""""
  7. michaelm
    Feb 2, 2001
    872
    <a target="_blank" href=http://performanceunlimited.com/documents/balancingpowder.html>http://performanceunlimited.com/documents/balancingpowder.html</a>
    read this info.
  8. 76chevy
    Aug 16, 2000
    246
    Utah
    Wow! Thanks for that article, I won't be trying that stuff. I'm just running 33's for now so I will get them rebalanced with weights.
    I'm getting a shaking at about 60mph I think is comming from either the front left tire or ball joint. I was hoping to use the equal because it seems my tires get out of balance every 5-6 months.
    Thanks for your input folks.
  9. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I used it in my Swamper 35s. It worked real good till I filled my tires with air from a gas station. There was more water than air coming out of the hose and it totally messed the powder up. If you use it, make sure you only air up from a good water free source.
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Aint Skeered!! </font color=red>
  10. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    I just had tires put on my work semi, they used equal in my steer tires. I have noticed a big difference. I was talking to the installer he said they have special shrader valves w/ screens in them. So if you do get air from a service station w/ moister it will help to disperse the water. It will make smaller clumps. Dry air is the key.
    Hope the helps.
    Later Ed
    Get use to the view.
    Because, if your not the LEAD DOG the view never changes.
  11. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    I use that stuff every day at my work and it works good but dont wast the money on them for your trucks I had the equal balance in my 36 swampers and the sand worked its way in to the valve stem and cused me to do a run flat so now I have a bad tire thats got 60% tread left on it. just my opinion
    colin
    Save the whales Harpoon a fat chick.
