Anyone tried ORD Zero Rates to level out their S-10?
Discussion in '1983-2005 S-Series models' started by BurbinOR, Apr 19, 2002.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    My rear on the DD sags a bit..............figured maybe the ORD Zero rates would be the right size for the job. Any input? I'll ask Stephen this too............
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    No zero rates on the back of mine. I installed the Rancho add-a-leaf on each side to bring the rear up about 1.5 inches. But I can definitely tell that it rides stiffer when it isn't loaded. The zero rates might be just the ticket. /forums/images/icons/cool.gif
  3. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Oops, I just remembered. The S-Jimmy has the rear springs under the axle. /forums/images/icons/blush.gif So adding the zero rates would actaully lower your truck by an inch! /forums/images/icons/shocked.gif
  4. BurbinOR
    5,829
    Oregon
    Well, that wouldn't work then............./forums/images/icons/laugh.gif. Maybe add a leaf is what I'll have to do then.
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I've thought about using them on my s-10 to level it out...it sits about 1" high in the rear...I think I'll just remove a leaf and see what happens though.
  6. outsider223
    outsider223 1/2 ton status
    Mar 17, 2002
    122
    Green Bay, WI
    The previous owner put 2 add-a-leaf's in, so now the rear is about 1.5 inches high. I was thinking of cranking the torsion bars to level it out.
  7. scotty1
    scotty1 1/2 ton status
    Jan 7, 2002
    166
    WV, Harpers Ferry
    I had the add a leaf put in my truck rear as part of my lift plan. The factory monkey metal leaves were sagging also on my truck, the add a leaf brought it back up but stiffened the rear up a lot. The stiffness is very noticeable in a light truck, if you haul some weight most of the time it will temper this stiffness out. BTW I still had to go with lift shackles to get the rear up to even out with the front.
  8. BurbinOR
    5,829
    Oregon
    OK, in lieu of using a zero rate (won't work) or a add a leaf (been there on my '85 S-10, the ride then sucked)..........how about LOWERING the front an inch to compensate, by manner of the torsion bars? Sounds crazy /forums/images/icons/crazy.gif I know but it would at least level it out and ground clearance is not an issue with my Jimmy. That's what the Blazer is for.
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Blasphemy! /forums/images/icons/shocked.gif You would probably be resting on the front bumpstops pretty quickly. The stock setup doesn't have much upwards travel to begin with. I'm running 30x9.50 General Grabber AP's on the stock alloy wheels. Even at the stock height, they rubbed the back of the front wheel well when it got crossed up. With the torsion bars cranked up, they haven't touched again. /forums/images/icons/cool.gif
  10. BurbinOR
    5,829
    Oregon
    Thanks for clarifying that bad idea.............but 'Blasphemy'? What is this, some cult??? /forums/images/icons/laugh.gif
    Guess I'll leave it be............ooooorrrrrrrrrrrrrrrr............how about a rear extended shackle? Possible?
  11. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    When I had my S-10 I was going to get extended shackles. Probably the easiest, cheapest way to get a little lift in the rear. You could even make them your self relatively easy. Maybe make them 2 or 3 inches longer for a 1- 1.5 inch lift.
  12. scotty1
    Jan 7, 2002
    166
    WV, Harpers Ferry
    Go with the lift shackles! You should be able to get a good set for $35-50.
  13. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I actually take mine off-road so the shackles would just make the rear overhang worse than it already is. The add-a-leaf did stiffen up the ride a bit, but it doesn't feel like the axle is welded to the frame or anything. /forums/images/icons/wink.gif It was my wifes daily driver for many years and she never complained about the ride after I installed it. /forums/images/icons/cool.gif
  14. BurbinOR
    5,829
    Oregon
    This will not be used to wheel..........Blazer has that duty. This is for ski trips, general DD duties and nasty weather (rarely get that here) security. Shackles are a good idea, I had the add a lift on my 85 and it made the ride suck.
    Thanks for the feedback!
  15. ChevBlazin
    Feb 4, 2002
    332
    The lift shacles will Not make the rear overhang worse. Your leaf spring is still as high off the ground as it was when the factory shackle was on it, but your rear frame moves up and makes it look like the springs are lower. Think if you were able to install them with the wheels on the ground, all that would happen is the rear frame would go up and then you bolt the shackle in. I suppose there could be a miniscule ammt of ground clearance lost since the pinion angle changes a bit thus makeing the rear of the spring hang down very slightly. But seriously, would you notice that?
  16. ChevBlazin
    Feb 4, 2002
    332
    After thinking a bit more, I recant some of that statement. A little clearance would be lost. sorry. However, on my 84 S-10 my trailer hitch and bumper always hit first, so I wouldnt have cared.
  17. Blaze
    Blaze 1/2 ton status
    Aug 28, 2000
    3,285
    Raleigh, NC
    It doesn't make my clearance worse. I got at it with the sawzall. *grin*
  18. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, I try to line up rocks so that the hitch takes the majority of the abuse when dropping into holes, creeks, etc. The longer shackles would tend to make the springs hit the rocks first. /forums/images/icons/shocked.gif
  19. Emmettology 101
    May 9, 2000
    8,126
    FL
    My friend used an add-a-leaf in the rear of his ZR2 Blazer. It still rode very nice! Make sure you get the long add-a-leaf, they ride alot nicer. Not sure what my friend got though...
