Anyone tried this?
Discussion in 'The Garage' started by fireplug, Jul 20, 2006.
  1. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
  2. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    No, I never thought of doing that, but I wheeled the pee out of my 10 bolts (didnt really care), I went through mud and water all the time, and never had to repack the bearings. When I took it apart to do the D60 swap, I did not see the slightest damage from "neglect". I would just use a good synthetic grase and not worry about it.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you have manual locking hubs alot of grease is bad for them. It can make them not function correctly. If you have driveslugs like some Jeeps do then it wont be a problem.
    Harley
  4. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    My concern is that if you are greasing because you have been in water, Where is the water going? Without disassembly you can't get rid of the problem that you are trying to solve. Plus your building allot of pressure around the hubs with all that grease which will cause them to act up as Hossbaby50 said.
  5. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    That and the whole problem of removing and installing the grease fitting every time you take the wheels off.
    Think the guy said remove the hub and pump grease until clean flows out.
    I'd like it a lot better if the new grease could actually make it to the bearings. Kind of like those bearing buddies for boat trailers.
