Anyone try the chevy crate 383 truck engine
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by turbo, Dec 31, 2000.
  1. turbo
    turbo 1/2 ton status
    Feb 18, 2000
    109
    If so what do you think of it.
  2. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    When i run into $3500, i'll let you know.
    Keep the shiny side up, and the greasy side down.
  3. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    Wow you might want to shop around. I just saw it for $2769 at <A target="_blank" HREF=http://www.paceparts.com>http://www.paceparts.com</A>
  4. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I'd like to know also...I am thinking of putting either my TBI on one or maybe getting the system from a Z28/Vette and McGuyver-ing it together....I know the TBI would be simplest, but I'd sure like to have MPI....I think I can do that for under $5000....JD
    89 Jimmy headers built 700R Auburns Molys 4:10 4" 10B/12B Con-ferrs 10" Rallies 33" BFG Muds Alpine/Fosgate
  5. SVBlazer
    SVBlazer 1/2 ton status
    126
    Boxford, MA
    I currently am running with a 383. The highlights are lots of low end torque. 'Course the cam is heart of this beast. My current cam is a custom dual profile RV grind. The numbers are fairly impressive. 427 ft/lbs @ 3200 and 407 hp at 5500. With all the bolt on stuff, headers, carb, spark box, belts and BS the package cost around 6k or so. My advise is find a shop with a dyno, have them build it, tune it and enjoy.
  6. Cavalry
    Oct 1, 2000
    978
    SVBlazer....whats the numbers on your cam? On your dyno runs did you just get the peak #'s or did they give you the entire range? I would be intrested in the dyno run #'s too if you have it.
    <P ID="edit"><FONT SIZE=-1>Edited by Cavalry on 01/01/01 07:14 PM (server time).</FONT></P>
  7. Woodman89
    Woodman89 Registered Member
    Jul 27, 2000
    60
    New Hampshire
  8. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Sorry guys That GM 383 Crate has been pulled from the production line, so says Pace Motor!!
    I called on that about two weeks ago and they said GM's product management had a change in personel and the 383 Crate was pulled from production[​IMG]!!??
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  9. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    Try this place, it's a little more $ but alot more motor.
    <A target="_blank" HREF=http://www.autoengines.com/c38.htm>http://www.autoengines.com/c38.htm</A>
    [image]C:\father&son.bmp[/image] I have to agree with the Puddy Cat. [​IMG]
