anyone use a cutting torch to remove old spring hangers?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Sep 30, 2001.
    on the last shackle flip i did i used a combo of angle grinder and drilling. drilling being by far the slowest method. the grinder is ok but hard to get into some spots. can i use a cutting torch and burn out the rivets?
    <font color=blue>"What does mine say?"
    "SWEET! What does mine say?"
    "DUDE!" </font color=blue>
  1. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    Just blow off the rivets heads with the torch then drive out the rest with a punch. I have done it this way many times and never had a problem.
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    I looooove using the torch. You have to be careful not to heat up the frame alot so you won't lose strength though. Ever try an air chisel? That does a nice job too. Just make sure to drop the tank when you're playing with the torch.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  3. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    I've tried it a few ways. I think the best way I found was to use a air hammer with a chisel bit to sheer the head off, then used the same hammer with a punch bit to pop the rest of the rivet out of the frame. Not only was it relitvly fast, and made a ton of noise, it was fun to. The back half of that rivet reelly flies out when you punch it threw the frame.[​IMG]
    Twiztid
  4. never thought of the air chisel. bet my nieghbors would love that!! dont' know if my wimpy 2 hp air compressor will run an air chisel well though. kinda leaning towards the torch. but i don't have one...
  5. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    I second the chisel method. I did it last weekend on mine. It doesn't take very long and keeps from changing the temper of the frame. I then used a #1 unibit to open up the holes, worked like a charm!.
    73K-5: TBI350/TH-400/NP-203/14FF/D44
    Topless, doorless and no tailgate!
    Fresno, CA
  6. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    I've done it a couple of times with the "blue wrench". No problem, just do as stated above. Blow the heads off of the rivets and then knock them out with a punch. Much quicker and quieter than an air chisel.
    '85 K5 : Run it til it breaks, then fix it and go again!
  7. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Yes, done the flip on two different trucks and used the "hot wrench" both times. works like a charm, fast and easy. I used the air chisel to punch out what the torch didn't get. And yes, it's LOUD!
    Boss
    Pic of my truck Before N' After
    <a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
