Anyone use an Ignition Control Box
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Lazydog, Apr 3, 2003.
  1. Lazydog
    Lazydog 1/2 ton status
    Apr 17, 2002
    129
    Phoenix, Arizona
    Anyone use an MSD 6A multispark Control box, or any other Brand multispark discharge unit? How do you like it?. Did it improve emissions, power, mileage etc? Thanks
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    i had one on my truck when i bought it, but it developed a short in it, and i took it off. it was an MSD 6A i think...truck definately started easier, and was smoother at higher RPMs
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have the MSD 6 Offroad box on my truck. I really like it. It improved throttle response very well with my carb, and also helped out with passing power, mileage, starts, and everything else they claim. Personally it is one of the best mods I have done. I also run many other MSD products because I was so happy with there stuff. Here is the full list of what I run.
    MSD 6 Offroad Box
    MSD Cap & rotor
    MSD Super Conductor 8.5mm wires
    MSD Blaster SS coil
    MSD Coil wire
    MSD HEI dust cover
    and hopefully sometime soon I am getting the MSD adjustable timing control unit and MSD Pro-Billet distributor.
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I am using an MSD 6AL. I've had great results like Hossbaby50 has. I would recommend them!! /forums/images/graemlins/thumb.gif
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    what kind of gains did oyu get from your dust cover? /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  6. nvrenuf
    Jan 7, 2002
    13,075
    246
    Mobile, Al.
    I run a 6AL, MSD distributor, Blaster2 coil with Taylor 409 wires and I love it! The biggest benefit I noticed was that it cured my plug fouling problem (due to BIG carb). My set up is about 6 years old now and if it died tomorrow I'd buy all of the same stuff again.
  7. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    The dust cover is an adapter so you can use an external coil on a HEI setup.
    Dan
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    DesertDueler is right. The dust cover is one there so I can run an external oil on a stock cap. I am running the Blaster SS coil which is supposed to be a better coil then the incap standard MSD HEI coil.
  9. Lazydog
    Apr 17, 2002
    129
    Phoenix, Arizona
    Thanks for the posts. I don't have a lot of money, Can I just use the 6A Ignition Control now, and then add other parts later? Did anyone change the module in the distributor?
  10. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    You can buy the box now and add on the other stuff later. Also, if you run an ignition box like a 6A you don't use the stock module anymore. You don't need to upgrade it to the high output module because you don't use one anymore.
  11. Lazydog
    Apr 17, 2002
    129
    Phoenix, Arizona
    Okay I didn't know that. Do you remove it completly then?
  12. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Yep. your condensor and module come out completely. The MSD box hooks directly to the pickup coil leads that the used to go to the module. This is the way mine is setup. Mine was a 4 pin module. It might be a little different on the later 5 & 7 pin modules, but the directions are pretty good and explain everything well. Don't throw out the old condensor and module though. Keep them and there bolts incase something should ever happen to the MSD you can go back to the stock setup. I keep mine around just incase.
