Anyone use this 208 SYE kit?
Discussion in 'The Garage' started by txbartman, Nov 6, 2002.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Always looking for a SYE for my 208. Found this one today from Driveline Solutions. Anyone use this, have any experience with the company, or know any other such kits?
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    thats the only one for the 208 i've ever seen. i've done some reading up on it and i would say it should work just fine. i would just say that you would have to make darn sure that your bolt hole is centered on the output shaft.
  3. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    From looking at the eliminator pictured, I figure to place it on the shaft and use it to help me determine where the hole should be drilled and so forth. Using this method should work fairly well.
  4. txbluethunder
    Jan 29, 2002
    835
    Austin, TX
    i agree...and their price for kit 2 seems to be priced pretty well. if you do it i, along with many others, would love a write up. /forums/images/graemlins/smile.gif
  5. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    The end of the output shaft is already drilled out somewhat for the live center to hold it during machining, so that will center your drill. The hard part would be to make sure you drill it perfectly straight into the shaft. I've been kicking this idea around for quite some time, I guess someone beat me to it! /forums/images/graemlins/wink.gif Although I want to shorten the tailhousing too, along with bolting down the slip yoke.
  6. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    Put another one on the list. But i was under the impression that you can't just tap the out put shaft. I'd imagine that the metal is pretty darn hard. What I was thinking about doing was putting the tailshaft on a lathe and cut some threads into it. But to this point i was trying to figure out where to get the flange out put that would fit. Now i know. /forums/images/graemlins/thumb.gif
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    K10ANDYKHAMNIC has done a conversion himself using dodge parts. There is one small shaft support that has to be welded to the inside of the dodge case to make it work. He has posted about it before.
  8. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
