Anyone Used Cherokee Rear Springs in the front?
Discussion in 'The Garage' started by Flexy K20, May 20, 2003.
  1. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    I am about to do this becuase I recently installed a Rubicon Express 4.5" Super Flex lift on my friends 2000 Cherokee, and got his rear springs. They appear to be about 1/2-1" longer then my 4" Superlift Front Springs. I am going to put some of my superlift leafs in to stiffen it up a bit and I was just wondering if anyone has done this or tried to do this? The center pin seems to be almost right on. The cherokee rear springs should be considerably softer (Superlift's are pretty stiff) so they should provide more flex. Anything I should consider before I try this? Thanks
    -fLeXy K20
  2. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Take pics and let us know your results.
    Do you know what the spring rates on those are?
    Spring rates on the Chevy front springs???
    I hope they don't sag to the ground on you.....
    LMK
  3. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    -fLeXy K20
    Yes I have done it and it worked well. Here is the pictures of it. http://www.rustbucket.rockcrawler.com/photo.html Also if I would do that again I would move the front hanger forward 2" and use a 6" shackle. I used the top spring for the XJ and XJ add a leaf and the bottom 5 leafs was from a Wagoneer 6 leaf pack.
