Anyone used this Np241 clocking ring?
Discussion in 'The Garage' started by afroman006, Oct 19, 2004.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Clocking Ring
    This is made by the same guy that does the crazy beefy diff covers and it looks great to me but I was wondering if anyone had any personal experience with it. Thx
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I know he makes good diff covers and he stands by them, I would assume he is a good guy since he has a good rating on ebay, I might just by one today, he is cheaper than what I have found /forums/images/graemlins/thumb.gif
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I had the ring from DP90_k5 and that ring seems to be the same thing. The one I had was great. I sold it cause I am going to a driver side pumpkin and it would clock a driver side Tcase down instead of up.
  4. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
    What's required to do this install?
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    just a clocking ring and grinding the front shaft
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    ow and you have to adjust the shift linkage
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    at full clock you have to dimple the floorboards a bit but thats simple.
  8. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    even with an 1" body lift?
  9. afroman006
    Aug 21, 2002
    2,876
    I have a 3" body lift. When I clock it all the way up, I assume I wont have any body clearance issues. When you say modify the shifter, what do you mean? The little indicator looks kinda funny now that I put the body lift on but other than that its ok. I assume I'm going to need the front driveshaft lengthened because I'm running 6" lift, and plan on having it rotated all the way up. I have a stock length shaft w/ a 1" spacer on the t-case flange now.
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    you will likely need a longer shaft. As for the adjustment of the shifter, you need to adjust it for the rotation. Same thing you should have done with the body lift. Look at the linkage, there is adjustment in it, thats why your shift pattern is a little off. If its bad enough it could cause you to skip out of say 4 lo or high when offroad. 1" body lift ,I know on a Suburban you don't need to dimple the floor when you have that.
  11. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I have a 2" body lift on mine. I clocked mine all the way up AND raised the entire drivtrain up abou another inch and half. I had to actually cut the floorboards because there was no way of "dimpling" them to make it fit. BUt now I have a flat belly with a skid plate from frame rail to frame rail. /forums/images/graemlins/peace.gif
    Here are some more pics.
  12. 91GMCSuburban
    Dec 9, 2002
    318
    San Antonio, TX
    grinding the front shaft?
  13. afroman006
    Aug 21, 2002
    2,876
    Good god what size plate did you use? That looks like 3/16. Must be one heavy pig huh?
  14. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    You can grind the stops in the CV on the front shaft. It will give you a little more angle, but not much.
    Esteban86K5 how much lift do you run?
  15. Esteban86K5
    3,712
    Bakersfield, CA
    It's 1/4 inch and it's not horrible heavy.
    I ground the stops on mine and extended it a couple of inches and it has worked for me so far.
    And I run 4" suspension with a zero rate in the back and 2" body lift.
  16. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    Esteban, how was you pinion angles front and back?
  17. Esteban86K5
    3,712
    Bakersfield, CA
    I have a shim in the front that puts my front pinion angle within a workable range. And in the rear I had already relocated my spring perches so the rear axle was already rotated for the better pinion anlge. After I raised the drivtrain up I left it the same and it hasn't given me a problem yet. I'm sure it's a little off but not enough for me to worry about on a rig that doesn't see much street driving.
  18. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    thanks. /forums/images/graemlins/waytogo.gif
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That flat belly is soooooooooo sexy. /forums/images/graemlins/waytogo.gif
    And tell the truth, you have High Angle Drivelines, that's how you can get away with this.
    guys, if you do this, WATCH YOUR ANGLEs, especially on that front driveline!
  20. Esteban86K5
    3,712
    Bakersfield, CA
    That is VERY true. I forgot all about that. I do have HAD driveline in the rear. /forums/images/graemlins/doah.gif
