Anyone using 15" alloy wheels on 14bolt FF drums?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shum1, Jan 21, 2001.
  1. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    Anyone using 15\" alloy wheels on 14bolt FF drums?
    Ive heard that steel pokes will fit but I'm not sure if aluminum wheels will fit due to their thicker castings, anyone know? Thanks
  2. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    Re: Anyone using 15\" alloy wheels on 14bolt FF drums?
    I would imagine that the extra thickness of the aluminum rims would be towards the inside of the tire. Don't know 100% for sure though. Anyways the fitment over the rear drums is pretty well a non-issue, even if they do touch the drum a little, it turns with the tire anyways. [​IMG] It's the front that is all the fun.
    Rene
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>The only company that i've ever seen make 15 alloy wheels is Weld. They were custom-made ( $$$$$ ) and require driveshaft brakes. If you want fancy alloy wheels, you need 16" (limited tire choices) or 16.5" (can't air down). </font color=blue>
    <font color=blue>pavement queen with shinny paint job and car tires</font color=blue>
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It takes a lot of caliper grinding to make 15-inch steels fit up front. Alloys are much thicker, so I'd be surprised if they fit at all. I haven't seen any 15-inch, 8-lug alloy wheels in my search. Some from Weld are mentioned above, but it sounds like you have to remove the brakes on the wheels and go with a brake mounted to the driveshaft. That wouldn't even work in your application, unless you want to keep the front hubs locked all the time so the brakes would work.
    If you don't air down, 16.5-inch wheels are OK. I'll be getting rid of a nice set of aluminum slotted 16.5x9.75x8-lug wheels soon. I air down off-road and need to go with the 15 or 16 inch wheel.
