Anyone using a GM crate motor?
Discussion in 'The Garage' started by badmix, Jan 6, 2007.
  1. badmix
    badmix 1/2 ton status
    Nov 7, 2004
    4,205
    60
    West Virginia
    Im thinking of goin with the 260hp/350tq. Its alot more than my OEM 305 and comes with a warranty. Jus wondering if anyone has getting this motor and is there a big diff. between 2bolt main and 4bolt. I dont drive my truck hard or mudbog or rock crawl it, jus some trail riding and what not.
  2. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    i dont have a GM crate motor but if youve got a tired 305 that motor should be a nice improvement and should do just fine for what you do. the diff between 2 bolt and 4 bolt mains is the number of bolts holding the main bearing caps on. 4 bolts will be stronger but they arent needed unless youre building a motor with much higher hp.
  3. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Check again, if thats the basic Goodwrench motor I think it has 4-bolt mains. Mine does.:D
  4. badmix
    Nov 7, 2004
    4,205
    60
    West Virginia
    Ah, your right, I jus re-read the ad. its a 4bolt main with 2 piece rear main seal. that must by what I seen was the number 2 and thought it was 2 bolt. My bad. So, im good to go. lol
  5. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Awright, you won't be sorry.:D
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I run the same one and it is a great motor for the price.
  7. CutlassKid85
    CutlassKid85 Registered Member
    Apr 18, 2006
    76
    Texas
    My k5 came with a goodwrench 350, is there any way to tell/track what it put out when it was new? Its only about seven years old.
  8. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I don't think they were mass producing the powdered metal (PM) rods back then? And 4Bolt Goodwrench :dunno:
  9. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    That Goodwrench universal 350 is a good motor. If you can, I'd swap the cam for something a little newer and bigger from Comp or another manufacturer. With a little more cam and maybe even some 1.6 rockers, I'd expect quite a few more horses out of that motor. You could always add better heads down the road if you wanted more power.
  10. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    there goes that warranty....
    for most guys a fresh 350 is a big improvement over what they are running now. If you are REALLY looking at going the crate engine route and the HP of that engine isn't enough, look at stepping up an engine level or two.
    For the MAJORITY of people, 2 bolt main blocks are just fine. Everyone just thinks they need 4 bolt mains.
  11. badmix
    Nov 7, 2004
    4,205
    60
    West Virginia
    The whole reason to get this motor is the warranty. I have no intent in monkeying with it. Im pretty sure 260hp/350tq is alot more than my 120k mile factory 305 puts out. :D
  12. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    ive got the290 hp one. from gm. its pretty bad. :) lol...then again i had a like 5 hp motor before...LOL. but its been pretty good so far. im runnin an edelbrock intake/carb adn will have hooker headers soon. But right now i think its pushin around 320-325ish. Like i said its a stout motor.
  13. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The only people who really need 4 bolt mains are the guys seeing huge rpms , over a longer period of time . Its overkill for most of us .
    It does have a urban legend feel attached to owning one , like anything with a 454 has , or how quick 700r4's die , or how 400 overheat too quick . Its just in peoples minds they HAVE to have one since its all thats been talked about since the late 60's .
  14. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
  15. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    where can you get one of these goodwrench crate motors at. also how much are they?
  16. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Less than $1500. Jeg's, Summit, Scogin/Dickey, Pace.
  17. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    Scoggin Dickey about $2100 for motor with edelbrock intake, edelbrock carb, mallory HEI distributor. That's the base motor with 260 hp. One thing I've found though and maybe I pay too much attention, in the catalogs (if you compare side by side) the jegs motor says it puts out more torque than the summit motor, but they are both the same GM stock number. Hmmmmm.... I"m also looking at the same motor for a daily driver pickup I"m putting together when I get home. I like S/D's kit because it has pretty much everthing to get started on a engine swap project minus the "little things" to nickel and dime you to death.
