Anyone using an Edelbrock or Holley Carb with a 700R4?
Discussion in 'The Garage' started by 83ZZ502_Jimmy, Mar 7, 2004.
  1. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    As the title asks, does anyone? If so can you explain how you hooked up the kickdown cable for the tranny? Any special parts or whatnot?
    If possible, a picture would be extremely helpful /forums/images/graemlins/bow.gif
    Thanks,
    John
  2. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    [​IMG] /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  3. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Did you have to buy an additional bracket to mount the TV cable end to the E-brock carb, or did it line/bolt right up?
    Thanks,
    John
  4. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    That is a pic from Summit, TCI bracket for a 700,$24.88.
    You will need a stud on the linkage for the TV cable, I think a new Edelbrock carb come s witha couple studs in the box, if not parts places have em. No extra linkagee is needed but if you really wanna fine tune th cable, check out Bowtie Overdrive and their new-fangled adjustable setup.
  5. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    you can do it that way, or call up bowtie overdrives and have them send you there TV made EZ kit for about $100 you can check it out on there website and in my opinion its worth the $$$ also you will probably wanna check your pressure numbers after doing either one /forums/images/graemlins/thumb.gif
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    When I had a 700R4, I used the stock throttle bracket and the little tit that the T/V cable fit over came with my Edelbrock carb so it didn't require any mods at all for me.
  7. Okiemuddog
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    I am using the stock bracket, only one hole will line up due to my carb adapter, but it stays put with out any problem.
  8. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    I used the stock TV bracket and I bought the little nipple at the local Checker Auto Parts. Everything went together and worked fine.
