Anyone using bend tech?
Discussion in 'The Garage' started by MNorby, Apr 9, 2007.
  1. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    Anyone using bendtech? Just ordered my jd2 model 3 bender. Is the software worth it?
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    the software is pretty good, i like to wing/measure it though, it is a lot faster for me, & i get the same result.
  3. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,496
    1,206
    So Cal.
    I have it but up to now I have not used it for anything I have bent up. my bumper, the cage I did for my buds zuki, tube doors I have started to make. I have had no real problems bending yet. I probably will be doing a cage here soon for a 2007 Nissan 4X4 fronteir that will be running in next years Baja 1000, in the stock truck mini class and I might try and see if it speeds things up for me.
    others say they it has helped alot. for the money it costs I would say get it.
  4. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    27
    El Paso, TEXAS
    Just an example:
    I have my own method of bending
    a good friend has his method (uses the software)
    for spits and giggles we had a little race: we didnt go any faster than normal--we both had the same measurements and said go.
    no kidding, as soon as I picked up my paper he was walking out the door.
    I feel it depends on how much you have bent already--if you have a method and can put out a good product keep doing it.
    If you are relatively new to bending i think it will help you out and will be worth the money
  5. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    I have the bend tech but haven't really figured out how to use it. This is all I use http://www.pirate4x4.com/tech/bendin_tube/
    Read it, learn it, live it. This is the easiest and best info I have seen on bending tube. I have built several cages, bumpers and other parts using this and it works great.
    Brent
  6. MNorby
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    yeah I have been built alot of tube stuff just curious if it really helps or not.
