anyone using ord 1'' body lift
Discussion in 'The Garage' started by suburban n progress, Oct 25, 2005.
  1. suburban n progress
    suburban n progress Registered Member
    Apr 15, 2005
    19
    Florida
    Was gonna replace the suburbans old body mounts but saw these are aluminum...As far as i can remember..aluminum and steel like to corode eachother after time...i thought they used like a daystar poly but guess not..anyone using these and good or bad????
  2. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,069
    206
    Colorado
    The ORD aluminum pucks have been around for quite a while now. The metal vs. AL. is not an issue. I also think the way they stack in that they may not even touck steel? I am not sure.
    I say no problem go with them.
  3. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
  4. suburban n progress
    Apr 15, 2005
    19
    Florida
    well
    i just ordered the steering box brace and the shackle flip hanger and there new shackles...THOSE ARE BAD ASS and i opted to wait on the body lift...but if yall think its fine i just thought the polyurathane mounts let the body "adjust" better than a piece of aluminum..Anyone know of any changes to be made to the rest of the truck such as transfer case linkage or any adjustments needed anywhere else..its only a inch..but i know on my wrangler 2'' threw a LOT of stuff off..thanks again.
  5. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    the chilton manuel helped me alot when i adjusted my tranny after i put on the new body mounts. all i had to do for the tranny is loosen the nut on the end of the rod and tap the rod out some more, tighten it back up and its good as new.
  6. suburban n progress
    Apr 15, 2005
    19
    Florida
    sweet well thanks a lot for the info..some how ill post up pics soon
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I have had their kit on for a few years with no problems.
  8. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    After installing the ORD 1" body lift I had to adjust the transmission linkage as stated above, adjust the transfer case shifter, and do major surgery on the bottom half of the fan shroud. The aluminum to steel is a non issue.
