Anyone using the MSD 6A?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Marshall, Jun 22, 2003.
  1. Marshall
    Marshall 1/2 ton status
    Apr 8, 2002
    204
    LiveRmore,CA
    Hi, i was wondering if anyone is running an MSD ingnition control. I was thinking about getting the MSD-6A or the 6AL and was wondering if there is any significant performance gains over stock /forums/images/graemlins/thinking.gif. i am aware that the only diffrence between the two units is the rev-limiter(not sure what i would use it for). I allready have the blaster coil so thats a plus /forums/images/graemlins/grin.gif Thanks for any help provided
    Thanks again, Marshall /forums/images/graemlins/k5.gif
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    if you have an automatic just get the 6A
    i got a bit better mileage with mine. and power increase was noticable, but not much. kinda like what i got with my K&N. im going to put one back in my 74 as long as it will work with the TBI. i just need to find that out.
    advice on installing it, tear your dash appart and mount it inside the dash area.
    Grant
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    always mount ignition modules as far from heat as possible, especially msd, they hate heat...
  4. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    I put my 6A in last summer along with a MSD super HEI kit.
    http://store.summitracing.com/product.asp?d=11&s=141&p=1141&searchtype=ecat
    It improved throttle response, gas mileage, more power, and it allowed me to run a lower idle rpm. I've heard a lot of people who complain about the boxes giving out. This problem is due to fluctuating input voltage associated with using a lot of power accessories, or jump-starting a vehicle. MSD makes a fix. It is called a noise filter. You can buy one from Summit here:
    http://store.summitracing.com/product.asp?d=11&s=141&p=1121&searchtype=ecat
    They basically even out the input voltage and eliminate the reliability issues. Confedneck was right about heat also. Keep them out of the engine compartment if possible, if not keep them as far away from the headers as possible. If you take care of them an MSD is a great ignition.
  5. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    I have a 6A and I love it. I got better mileage, throttle response, and efficiency. I put my own rubber feet on it to stop from vibration, and dont need a rev-limiter. That's the only difference between the 6A and the 6AL. I mounted it on the upper left of the firewall and have experianced no problems. /forums/images/graemlins/truck.gif
  6. jhrody
    jhrody 1/2 ton status
    Feb 16, 2003
    129
    Elmhurst, IL
    i have a 6AL in mine.......mounted on the inside firewall just behind the gloebox...using the 6500rpm limiter cube or chip or whatever you want to call it.
  7. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I am using a 6AL and have had typically the same results as the previous posters. I have had mine mounted in this position for 3 years without problems. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  8. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    why didnt you go w/ the offroad version? b/c of money?
  9. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Cost was the biggest factor. The 6AL comes with the same rubber mounts as the Offroad version. Like I said, no problems at all. /forums/images/graemlins/thumb.gif
  10. Marshall
    Apr 8, 2002
    204
    LiveRmore,CA
    how long is the wires leading to the battery.....do i need to get longer wire to mount inside the cab?
  11. pismorat
    Oct 29, 2002
    540
    California
    I couldn't mount mine there because thats where my Dixie air horns are!! My wires run along the firewall to my main battery on the left front, about 6-8 feet I'd guess. /forums/images/graemlins/truck.gif
