Anyone w/205 in pieces right now?
Discussion in 'The Garage' started by dyeager535, Dec 1, 2005.
  1. dyeager535
    26,982
    191
    Looking for a good picture of a fixed yoke rear output shaft, (out of the case) from a 205.
    I was just told that the shafts are all the same, but I find that partially hard to believe unless the VSS reluctor ring simply replaced the speedometer gear, which now that I think about it, may have.
    Need to replace my 1991 VSS output shaft, already have an older 205, if the swap is that easy I'm golden. If not, minimum $200. :(
  2. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    if you can wait a couple of weeks I should have mine apart... rebuilding it and need to completely tear it down so I can machine the input for the bigger 32-spline-friendly bearing....
    j
