Anyone welded both front and rear?
Discussion in 'The Garage' started by k5-newbie, Sep 1, 2005.
  1. k5-newbie
    k5-newbie 1/2 ton status
    Jun 19, 2004
    399
    Huntsville, Texas
    I just got done with my 5.13's and I welded the front D60 and the rear 14FF. I know this is not the "proper" way to lock them but it is all I can do right now. I plan on a ARB or electric for the front and will probably do that when I upgrade the axle shafts.
    Anyway, just wondering if anyone has had any probs with the front welded and what I need to look out for (besides driving it locked on the street).
    TIA
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    My front is welded. Though I hevent even put the axle in the truck. It is a must that you have crossover and hydro assist, thats the only way it makes it doable.
  3. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    found out about the hydro assist this weekend...I tapped my box just haven't got the ram and the lines yet.
  4. short sub
    short sub Registered Member
    Jan 17, 2005
    98
    Sealy Texas
    hey man hows it goin? i am welded front and rear and for the $$$$, well ya cant beat it. Ive owned rigs with detriots before and i cant see spending the money on one when it basically performs the same- except now that im twinsticked in the front i could disengage it and leave the hubs locked with no probs. but oh well. I am running full hydro- a steering upgrade is definetly required and i busted a 35spline inner which may have been due to the added stress. It works though. Later Ryan
  5. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    I have a mini spool up front (not welded, but the same efect) and have no steering upgrades, and I have NO PROBLEMS :D I love it! Cheep, better maners than a locker, and I can drive out of ANY rut in the trail ;)
    Only tip I have for ya is: when it will not turn as tight as U need, just stand on it :D :bow: It WILL turn hard and fast.
  6. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    It would be a good idea to plumb in a cooler on your power steering system...you can use a tranny cooler and it just plumbs into the low pressure line, very easy :D Your power steering pump will thank you :waytogo:
  7. Geargrinder
    Jan 21, 2005
    258
    Medford Oregon
    That is a Damn good idea! I think I will do that this weekend :bow:
  8. chevyguybc
    chevyguybc 1/2 ton status
    Nov 12, 2003
    524
    Vancouver Canada
    well im going to a welded front rear setup, 14 bolt ff rear and dana 44 with warn hubs... hubs seem easy to engage, im going with stock steering for now, then dana 60 with xover soon..
    anyways the diff came welded to me.. im going with a square shaft, so u joints will be my weak point, just the way i like it
  9. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,005
    829
    Pinckney, MI
    Sounds like your in the same situation I am, except I will be welding my 44 soon. I just dont want to dump money into my 44 when I have a 60, it just needs hubs, rotors bearings etc.
  10. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    Welded front and rear and love it and the money I saved. On trails its amazing and easy, on rocks its more interesting but still easily tolerable when I look at what I saved. I wouldnt have done it though if I didnt have crossover and hydro. I will be adding the cooler tonight.
  11. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I am thinking about welding my front 60 as I do not have the money for a detroit yet. I have crossover but no Hydro what are the cons for such a set up. I will have another set of internal gears to put in if I do not like the welded front.
    Ira
  12. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    im looking at runing stock steering until i have all the peices for the crossover
    found flattops for 75cdn buck local
    arms are 80us on ebay
    tir rods will be cheap
    30us for tie rod threades sleeves
    and i have the 2wd box
    so i should have crossover soon
