Anyone who put the 1 inch body lift on their Blazer. quick ????
Discussion in 'The Garage' started by Silver84k5, Nov 7, 2002.
  1. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Did you have to drop your gas tank to install it? thx.......
  2. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Yes
    I have a 83 and I had to drop the tank some older years mite not have too, I think anyway. make sure you use PB Blaster on the bolts for the staps or you will have to call LMC for new ones.
    Eric
  3. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    What would you have to drop the tank for? Just curious. Did my 2" without dropping the tank. The rear body mounts have access holes in the bottom of the frame rails to sneak in a socket on my '91.
  4. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    I did this last year and I drop the tank cause I could not get to the two back mounts I did not have enough room to put the new body mounts and the 1in lift in. I also think the instuctions said you have too drop it
    Eric
  5. nofeartruckin00
    Oct 5, 2001
    798
    Maybe i should have read my instructions /forums/images/graemlins/tongue.gif Did body mounts and 2" with the tank in. Sure those stupid brackets are stuck in the frame rails (tank has to be dropped to remove them totally), but it got the job done.
  6. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    You know that's another project that I should of taken pic's of so I could remember what a pain in the a$$ it was /forums/images/graemlins/shocked.gif. When I went to take off the straps both bolts broke, I ran around town for two weeks with tie down straps holding the tank in till the new straps came in from LMC.
  7. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    lol, mine came off pretty easily when i put the shackle flip on, Oh and get this, i dropped the tank, put the Shackle flip in, then i was so anxious to try my truck with the new softer leafs that i put the tank back in then after i got the tank in i remember i still had the 1 inch body lift in my garage. Thats why i started this thread i was hoping there was a way around not having to drop it again, guess not
  8. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    I was just looking somthin up and saw your question from before. I thought I'd get away without droping my tank for my new body mounts and 1" lift. I took the rear bumper off to see if that helped with the rear mounts I got everything loose and off then noticed that to get to the rear bushing back under the frame I am going to have to drop the tank. But the top one looks easy to get to with the bumper off. So I'd think the puck should be easy too.
  9. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I didn't have to drop the tank on my '73. Then again, I didn't replace the bottom bushing at my tank either.
    The poly kit I got was the incorrect one for my '73. I ended up using the original rubber bottom bushings for the last two rear sections.
    I did use Poly for the first three sections. I was after these sections so I can line up my doors. Then I installed the 1".
    If all your doing is a body lift, then you shouldn't need to drop your tank.
    Good luck.
