Anyone with 89 K5 and 4" Lift
Discussion in 'The Garage' started by caleb22, Mar 1, 2006.
  1. caleb22
    caleb22 1/2 ton status
    Apr 15, 2005
    193
    SC
    I have a 89 K5 with 4" TC springs, ORD shackle flip in rear, SX8000 shocks, and a 10 degree shim. When we did the lift the pinion angle difference was about 10 degrees.
    I still get a bad vibration from the drive shaft in the rear above 20mph, and especially when decelerating. I wanted to know from anyone who may have done the same type of lift combo what degree shim they used and if they did anything different.
    Just gathering info before we dive deeper. :)
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I have an 87 with 4" DIY flip in rear and my pinion is almost directly at my tcase. I did not shim at all but by calculations I need a 8 or 10deg shim. I do not have any vibes at all unless I coast. I am also running the stock driveshaft.
    I also flipped the brackets and run 56s in the rear.
    Ira
  3. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    I have a '90 K5 w/ 4" lift and mine vibrated too. I orderd a new shaft w/ CV joint from Rye Valley Oil and Gear. They came highly recommended. Mine has no vibration now at any speed.
  4. caleb22
    Apr 15, 2005
    193
    SC
    I took it all apart today and tried a 6 degree shim, still has vibrations at 20mph and higher, and under deceleration. I also put in new HD ujoints today as well.
  5. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    If you havent already you can try dropping the rear of the transfer case down. Pretty easy just to try to see if the vibe goes away. It worked for my 88
  6. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    i have 4 inch too and no vibrations
