Anyone with a 2002-2003 2500hd or 3500?
Discussion in 'The Garage' started by willyswanter, Oct 14, 2003.
  1. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I have a question on the newer duramax/8.1 2500hd/3500 pickups with an Allison. If you own one, preferably a long wheelbase crewcab long bed, does it have a fixed yoke on the transfer case rear output? If you have one of these trucks and could take a moment and just peak under and report back it would be greatly appreciated. Oh, if you do have it, could also please tell me your configuration as in crew cab, ext. cab, long bed, short bed, etc. Thanks /forums/images/graemlins/thumb.gif
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    I want to say that the 4x2's have a fixed yoke while the 4x4's have a slip yoke.
  3. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Well, I need to know on the 4x4 since my project involves the transfercase. I know on the 98 and older, when the 2 piece rear driveline was utilized, such as an ext. cab or crew cab, there was a fixed yoke on the t-case and a slip in the center carrier bearing. Hopefully some of the allison equipped trucks came with this...
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Hey Jason, Tony, (73K5Tony510) has one of those trucks. Eiher an 01 or 02 crew cab dually 4x4 with the 8.1 and Allison. /forums/images/graemlins/pimp1.gif
  5. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Dad's 2002 Duramax Crew Cab Shortbed is slipyoke with a hugeass aluminum driveshaft
    My 2003 Duramax Ext Cab Shortbed is a slipyoke with a steel driveshaft.
    Both have the allison and the 11.5" 14 bolt.
    Hope it helps,
    John
  6. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    My brothers' old '01 (Duramax 6 speed ex. cab long bed) had slip yoke and one piece shaft. New '04 (Duramax Allison crew cab long bed) has two piece drive shaft which he thinks has a fixed yoke. He will check and I will confirm later. /forums/images/graemlins/thumb.gif
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    '02 DMax/Alli SWB Crew 4x4 : Slip yoke
  8. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    01 Ext. Cab Dualie
    Duramax/Allison
    slip yoke...
  9. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ]Those things are huge! Has anyone tested out the factory limited slip yet? /forums/images/graemlins/ooo.gif
  10. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    So does anyone possible know if there is a fixed yoke version of the nv263 available? I really need a fixed 32 pline tail shaft...
    And why would GM go from a 32 spline input, 32 spline fixed rear output, 32 spline fixed front output on the 88-98 1 tons to a 29 spline input and front and rear slip yokes on the newer 8.1 and duramax trucks??? /forums/images/graemlins/angryfire.gif
  11. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    Another one of those great ideas from GM. My brothers crew cab has slip yoke (Dmax Allison long bed).
  12. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    02 crew cab, dually, 4x4, slip.
  13. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Mine works great! /forums/images/graemlins/thumb.gif /forums/images/graemlins/grin.gif
    John
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    No problems with mine, it's been used in the dirt, loose gravel, and on ice (which can get interesting with over 500 ft/lbs on tap /forums/images/graemlins/eek.gif )
