Anyone with a 383 Look here
Discussion in 'The Garage' started by Redfrog, Jun 1, 2002.
  1. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    What kinda of Gas milage are you getting,what gears,and what's your tire size. I am thinking of building one for a daily driver and am wondering what kinda of milage they get.
    Thanks in advance
  2. Highliner
    Highliner Registered Member
    Oct 20, 2001
    91
    Iowa Park, Texas
    About 14mpg avg. if you keep your foot outta' it running 4.10 gears and 35s.
  3. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    i built one for my k20 it has 3;73 gears with 35s it gets 9 mpg thats running prem. if you build one keep the compression down
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    WHat compression ratio are you running? (to keep it down?) Just curious.
    -- Mike
  5. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Will a 383 Have alot more HP and or TQ?
    Also I have heard a little about a 400 and a 415 stroker are these any good? Im trying to figure out the best small block
  6. Redfrog
    May 4, 2001
    753
    IL
    What compression are you running... I am going to try to keep it below 10-1 or so....
  7. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Go 8.5-9.0 to 1 so you can run cheap gas. Anything higher and you have to run prem.
    Dan
  8. Redfrog
    May 4, 2001
    753
    IL
  9. 4x4k20
    Mar 17, 2001
    1,699
    williamson ga.30292
    mine is 10 to 1i have the vortec heads
  10. Erich_in_AZ
    Erich_in_AZ 1/2 ton status
    Mar 23, 2002
    237
    Tucson (it\'s a Dry heat), AZ
    That's the same setup I had in my old 67 GMC pickup. Ran bad on cheap gas with any kind of load, or running the A/C. With premium, it had some kick to it. My mileage was about 10-12mpg with 3.73's and a 700r4, but I had a hard time being last across the light in it. /forums/images/icons/smile.gif I would try to keep the CR to 9:1 if I did it again.
  11. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    8-9 depending on my foot!
  12. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    about 15 on the highway. I've got 4.56's, 36" swampers and a TH350. I'm running 9.75:1 compression and have to use 93 octane, but it's worth it. Lots of down low torque and the hp is right there when I'm on the highway. I've got 375hp and 450 ft lbs. I don't think I'd ever run a plain jane 350 after owning a 383.
  13. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    383 mostly stock heads, RV (very close to the Edelbrock performer cam, just not as much lift) type cam. Auto tranny... with the Edelbrock carb and Unilite ignition I was getting ~15-16 mpg. With my HEI, and TBI now I am getting ~14 MPG.
    35s with 3.73s
    I am running ~9.5 :1 compression ratio, and I HAVE to run 91 octane... /forums/images/icons/frown.gif
  14. Redfrog
    May 4, 2001
    753
    IL
    Thanks for the replys, I think I'm going to bite the bullet and do
    it.. If I ever get my block back from the shop /forums/images/icons/smile.gif
