Anyone with a 79 Jimmy/Blazer HELP!!! ASAP!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sarazk5, Jul 4, 2001.
  1. sarazk5
    sarazk5 1/2 ton status
    Feb 19, 2001
    713
    Sacramento, CA
    K... here's my problem. The guy who owned my truck before me put the wrong harmonic balancer on. It is like off a 454 or something, i have no idea. Anyway, it hits/rubs my crossmember. There are several different options for the balancer when I call the parts store. They want an OEM number. So I figure if i find someone else with a 79, with a 350, it should be close enough. Can someone with a 79 please get me the part number off of your harmonic balancer? Would be much appreciated. Thank you.
  2. ArmyEd
    ArmyEd Registered Member
    Jul 1, 2001
    60
    Fort Campbell, KY
    The part number is on the backside of the balancer, therefore I think you need to take it off to get the number, The dealer should be able to get that info from a book, you shouldn't have to supply it, a 350 balancer is a 350 balancer if I'm not mistaken
  3. DaveDave
    DaveDave 1/2 ton status
    Feb 8, 2001
    247
    all sb chevy use the same balancer except the 400cid, so yours should be ok.
    i would check the motor mounts instead since 4wd use different mount.
  4. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    I may be wrong but I think theres only 2 diameters of balancer, 6"and 8". have you checked your motor mounts to make sure they are in tact. If they are boken or collapsed it would allow the balancer to hit most likely. My K5 is an 86 but I think this is pretty much a universal question. I am of course assuming that you have a SBC. If your running a BBC then I'm lost. [​IMG]
    PUREINSANITY If ya can't stop,Smile as you go under![​IMG]
  5. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    Sara,
    Are you certain that it's the wrong balancer? I've had the problem you mention, myself. It turned out that the engine mounts were just so worn that the engine had settled to the point that the balancer was rubbing on the crossmember.
    As far as I know, GM used 8" diameter balancers on most small block truck engines. But, you can get them in 6.25", 7.25" or 7.75" diameters, also. The GM Performance website lists several of these at: http://community.webshots.com/user/robbrj
  6. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    I too would check out the mounts.
    BTW a 454 balancer is externaly balanced and will not work on a SBC crank.
    my truck's not dirty, it's earth tone paint
  7. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Yup, check your mounts .....by the way, I'll be contacting you real soon about ordering some stuff from LMC for me ...
    L8r,
    . Riz . <A target="_blank" HREF=http://www.geocities.com/rizmonkey>http://www.geocities.com/rizmonkey</A>
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    What does the harmonic balancer have to do with engine torque?
    Tim
  9. jshadwick
    jshadwick Registered Member
    Jun 24, 2001
    45
    Sacramento, CA
    i have a stock 79 blazer if ya tell me where to look.
  10. xtremewlr
    xtremewlr Registered Member
    Mar 22, 2001
    17
    San Diego, CA
    In reference to the question on how the harmonic balancer can affect engine torque:
    The 8" balancer will be a little heavier than the 6" balancer due to the size. The added weight will help ing torque due to this (it will make the engine want to continue turning) but it will hurt the ability for the engine to rev up faster. Its all physics. On a race car, if you want to make a fast, high revving engine, you put on a light flywheel. But if you need more grunt (torque) then you install a heavier flywheel. the same idea can be applied to the harmonic balancer.
    Hope this helps.
  11. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    On the Blazer, find out where your timing mark tab is. There are two locations, straight over the top (you have to look between the water pump and block) or off to the drivers side. Also, the Blazer uses the smaller diameter balancer. Mines a 79, and the timing mark tab is straight over the top. The only difference between the two styles is keying on the crank to line up your timing marks. Some one told me to use the larger diameter for a little more torque, but there was not enough room between it and the crossmember.
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's what I figured--I just never thought it'd make that much of a difference. I didn't even think you'd be able to measure the difference.
    Time to look for an 8" balancer :)
    Tim
  13. Grim-Reaper
    7,385
    Atlanta
    Motor mounts and I don't mean just the rubber part I mean the bracket on the frame. My 75 had the rivits shear and the weight ot the motor rotated the bracket. I had to jack it up and put bolts in to correct the problem. The mouts rivit to the rail and the cross member. The Ones at the cross member are the ones that fail.
    It's not my damn planet monkey boy!
    <A target="_blank" HREF=http://communities.msn.com/OffroadK5s>http://communities.msn.com/OffroadK5s</A>
    Grim-Reaper
