Anyone with a 89 burb?
Discussion in '1936-Present Suburban' started by gmaniat, Dec 12, 2002.
  1. gmaniat
    gmaniat Registered Member
    Dec 12, 2002
    5
    Lawrenceburg, KY
    Can anyone tell me the exact timing on my truck? I recently put a new motor in and my shroud isnt original and that's where the timing set should be. If anyone could help me out I would appreciate it. Thanks
  2. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    O degrees...
    ...be sure to disconnect the tan/black single wire connector (outboard of brake booster), otherwise the computer will attempt to compensate, and then reconnect when finished.
    /forums/images/graemlins/burb.gif
  3. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    exactly what burbinator said.
  4. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Yeah, it's 0 degrees. Timing is controlled by the computer. To set it, make sure you disconnect the ESC from the computer. Should be a single wire I think under the dash...
  5. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    My balancer has 2 marks on it. Which one is 0 degs?
  6. Burbinator
    Sep 14, 2001
    898
    Tempe, Arizona
    Hmmm...
    I will have to look at mine since I do not recall TWO marks.
    I will let you know...
  7. muddysub
    Jun 23, 2001
    10,451
    489
    mine has 2 but i don't know which is which. /forums/images/graemlins/frown.gif
  8. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    If you don't have a timing mark on the front cover, you're not going to be able to tell. Sounds like your going to have to pull the driver's side valve cover and look for TDC on cylinder #1 and figure it out from there.
