Anyone with a body mount...
Discussion in 'Communication (CB | GPS | HAM)' started by Hayduke, Feb 17, 2001.
  1. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
    hey there all,
    so i've have my 102" whip for awhile and finally got around to buying a ball style body mount to install.
    what i found was when i took off the rear inner panel was that the inner wall and outer wall (truck body) was a little too far apart to mount this sucker up. am i gonna have to cut an "access" hole in the inner wall so i can mount this piece to the outer wall?
    i hope i didn't confuse anyone....
    peace.
    HAYDUKE
    Insured By COLT, Policy #.357M
    <A target="_blank" HREF=http://haydukesk5.coloradok5.com>http://haydukesk5.coloradok5.com</A>
  2. Peeetah
    Peeetah Registered Member
    Jul 3, 2000
    97
    Mt. View, CA
    Works good
    I did that this december. One suggestion, if you are using thee ball hitch I am thinking about throw out the three screws that come with it. With a little drilling you can replace the srews with grade 8 bolts. These will help make sure the ball mount stays on the Blazer.
  3. Hayduke
    May 9, 2000
    271
    NE Columbus, Ohio
    Re: Works good
    so you did have to cut an "access" hole to mount it? i was thinking about adding stronger bolts anyway....
    thanks!
    HAYDUKE
  4. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    Put one on mine a few years back and had to cut a section out of the inner wall too. Some quality time with a wizzah made it easy though. Use some aggressive screws though. Grade 8 bolts are a bit excessive though I think.
    Why do people keep calling it a Bronco!!!!!
  5. CV202
    Nov 14, 2000
    454
    Kingfield, ME
    Almost forgot, check and make sure you have a good ground plane, and match the antenna!! Fried a set of finals by trying to rush it.
