anyone with a desktop dyno? need help
Discussion in 'The Garage' started by Jonny-K5, Apr 2, 2004.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i'd like to aquire one of these programs,can anyone help me out ? just picked up a rebuilt 350. im wondering what HP it should be making.if not can you run the numbers for me?
    350 bored .040 over with 487 heads, isky 262 cam, performer intake w/ quadrajet and around 8.5 to 1 compression. also curious on what numbers it should make with stock ram horn manifolds or 1 3/4 headers.
    i was told the 487 heads are good flowing units. they are cast in 1970. are these good stock heads? better than the ones from the 70-80's?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    with manifolds
    hp: 250 @ 5500
    tq: 259 @ 4500
    w/ ram horns
    hp: 258 @ 5000
    tq: 277 @ 4500
    small headers
    hp: 296 @ 5000
    tq: 310 @ 4500
    big headers
    hp: 317 @ 5500
    tq: 318 @ 4500
    these are with 462 heads which are preaty good flowing double humps
    the 487 came with the 71-72 LT1 motors
    i got this program at autozone for 39.95 /forums/images/graemlins/waytogo.gif
  3. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    cool, thanks bro! /forums/images/graemlins/thumb.gif
  4. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    All those numbers mean nothing to you if based on a 462 casting head since those are 64cc heads and the 487 is a 76cc head.
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    but the flow is close, right. the cc of the head doesn't matter to this program just the compression
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Reguardless the numbers are inaccurate unless you have the proper flow numbers. DD 2000 is garbage in, garbage out.
  7. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    where are the numbers cast on head to tell what they are. ive never seen a 462 or 487 in any sequence on a head. how do you tell?
  8. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    they are in the valve cover area, between the 2nd and 3rd spring or the 6th and 7th spring. 462 or 487 are the last 3 numbers
  9. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    The amount of quench you have plays a big role in determining if it pings or not depending on the compression ratio. The cc's of the head are part of what changes quench area, along with deck height, and compressed head gasket thickness.
  10. alaskanbowtie
    alaskanbowtie 1/2 ton status
    Feb 15, 2004
    112
    ALASKA
    Desk top Dyno is just a figure and can be right, BUT also be off by 30 percent, so keep this in mind! My motor was estimated to make 359 with Desk top but there are alot of variables , i.e. gapless rings, quench, port work etc. Mine made almost 400 h.p. and 438 tq. on the real machine with a little tweeking but I paid 5 bills for this too. So just remember that it's just an idea and usually a little generous!! /forums/images/graemlins/waytogo.gif
