anything i can do while the engine is out
Discussion in 'The Garage' started by big83chevy4x4, Jan 15, 2005.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i noticed a crack on the engine crossmember but im out of argon/co2 and fluxcore. no one is open today or tomorrow to get the stuff, so i have to wait till monday. is there anything i can do to the frame or other wise.
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    more info
    i would update the crossmember to 85 up its stronger or make your own member. the 84 older units are pron to cracks.
    if you have a tractor supply nere you thay sell botlle gas and welding supplys.:cool1:
  3. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    im building a new one in the spring summer when i go crossover. id rather get the argon t the place i normally go to. they give me a lot better deal.
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    if you have a steering brace to install I recommend doing it now. Any trouble it may give you is easily dealt with when you can stand where the engine usually is. Thats how I did it on my Suburban, it was way easier than when I did it on my K5 with the motor in.
  5. dyeager535
    26,975
    Had the same problem on mine, only noticed it once the engine came out.
    As was suggested, update to an earlier crossmember. You'll see by looking at a newer one why they are better.
    Easiest way to get them out I was shown is to drill through the rivets with increasing size drill bits, then just use a chisel to cut the remaining head off. I replaced the rivets with large bolts, I believe 1/2". I also had the upper bolts (think thats right) for the crossmember welded in place, so they became studs. That way no wrench needed inside the frame rail to tighten those bolts.
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i don't have one, but i was planning on doing what steve frisby did on his burb. but i need argon to do that also. :frown1:
  7. jones
    jones 1/2 ton status
    May 17, 2004
    379
    IONIA,MI USA
    were you working on your truck this afternoon?i drove by to check it out but didn't have time to stop this weekend.kids/babysitting issues.there was ablack blazer sitting behind your truck.BTW,your truck looks tough,man.i hope to be able to check it out closer,though.
  8. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i didn't work on it at all today, too dam cold. the blazer is my dads.
    i pulled the motor to fix the flexplate and a few other things and my cousin talked me into dropping my "other" motor in it :grin: the motor that was in my truck im selling to my dad to replace his 305 in the blazer.
    thanks for the compliment, stop by anytime.
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    While the engine is out would be a great time to do some little subtle things like ..........clean up the firewall , paint things , clean your heat/ac box out , new frame motor mounts etc . The other things already mentioned before like steering box brace etc :)
  10. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    yea paint your engine while ya got it out for the extra BLING :)
    You could take a pic of it while its out :D
  11. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    its too cold to paint anything, tomorrow the high is suppose to be 15*. i get to work in the driveway also :(
    but i am gonna clean the engine compartment, it needs it bad (thanks for reminding me paul) my other motor is all preaty orange and gold :pimp1: ill be sure to take pics :pimp:
  12. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    Yep. Get a electric fan set-up when you put it back together and get back some horsepower like 20-30 ponies.:D
  13. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    you could be buying steel tubes for my drive shaft!!!! LOL i'll be there soon:D i would look for any probs that can be fixed without the engine in the way. thanks for the heads up on working outside on my shaft. i work out side so i have the cool carharts. about another week and i'll be there.:)
  14. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,003
    826
    Pinckney, MI
    Ummmm..... give me your bumper!!!!!heheh ;)
  15. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Bummer it's so cold. If I had my motor out, I'd pressure wash the snot out of everything and then go crazy with some POR-15, clean up and paint the firewall, etc. But I'm kinda weird about that kinda thing... :D
  16. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Hate to tell ya, but Monday is a holiday....so stuff might still be closed then.
  17. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    :mad: :mad: :mad: :mad:
    oh well, tuesday it is
  18. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Look at the trans pump seal ( if it is an auto ) and replace it if it looks questionable/brittle/seeping.
    Tom
  19. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If you live near a Home Depot, they carry 2 and 10 pound spools of the flux core wire and are open pretty much every day. :-) I've even seen the small spools at a Walmart...
  20. kyser_soze
    Sep 4, 2004
    3,180
    KC Missouri
    This is an excellent time to replace hoses if you need too.
