Anything special to paint over fiberglass?
Discussion in 'The Garage' started by TX Mudder, Mar 7, 2002.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I'm finally getting around to fixing some holes with fiberglass.
    I've already done one repair and learned a bit, so now I'm ready tot ake the vertical holes - the ones in the bed and cab from where I ripped the modling off.
    So, when I'm all done and the fiberglass is dry, I need to paint it with something so it won't look so bad until I get the whole truck painted.
    Does Rustoleum enamal paint stick right to fiberglass?
    I had a friend tell me I had to put a thin layer of glazing putty over the fiberglass before I spray it.
    -- Mike
  2. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    There has been numerious threads on painting, preping the fiberglass tops and such so if you do a search on painting the top or something like that you should get a ton of info. Hope this helps.
