Anything wrong with a pintle trailer?
Discussion in 'Tow & Trailer' started by 84_Chevy_K10, May 25, 2004.
  1. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I just looked at a number of trailers with pintle hooks on them here locally. They're 12,000 lb GVWR trailers. Any real problem with a pintle hook for towing my truck on?
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Just a little noiser. They are stronger and better for off-road use compared to a ball type hitch.
  3. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    A friend of mine pulls a tandem axle dual wheel pintle hitch trailer with an F-350 for the place where he works and he says sometimes it is scary when you go into curves because the pintle loop shifts on the hitch because it doesn't fit tight like a trailer ball does. With a heavier tow vehicle such as a dump truck it doesn't seem to be a big issue though.
  4. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    As long as the weight's pretty heavy, it shouldn't be a problem. It will be noisy with lighter loads.
    A good 2 5/16" bulldog hitch should be more than enough for towing just about any vehicle with the proper weight distribution setup.
    BIGJ
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I agree with you, these trailers happen to have a pintle because a 2 5/16" ball is rated for 10,000 lbs typically and that's about the practial limit.
    I'm going to look into what one may cost, I saw a decent used one I might inquire about that looked like it'd be perfect if it had a new set of axles and tires.
  6. bigjbear
    Feb 18, 2000
    13,970
    451
    Marietta GA
    Nope, I just towed a Tahoe from Cleveland, OH to Atlanta, GA on my new trailer. It clanks a little, mostly just in stop & go. I like it better than a ball but for no reason other than looks.
    That reminds me, I've got a story to tell.
  7. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I have a pintle and I think its fine. I've had it real twisted up and you dont have to worry about breaking a ball (which I've done).
    Its also a little harder to steal. /forums/images/graemlins/grin.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Well I ended up with a trailer with a 2 5/16" bulldog coupler. It's a good thing too becauase without a weight distributing setup I don't think I'd want to make long trips.
