Approach/departure angles
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84k5, Aug 20, 2000.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I was just wondering how you measure these. Thanks.
    Brian
    84k5, 4"Skyjacker lift,33x12.5 Goodyear MT/R, 15x10 Bajas
  2. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    From tire to the first piece of metal/plastic or whatever you hit....lay a straight edge on the tire where it strikes the ground...move it up until it hits something on the truck, measure angle and there you go....piece of cake...the more lift and tire you have the higher the angle... and witha little horsepower you can cheat that also!!!!
    <font color=blue>White Knight</font color=blue>
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    You can use a sheet of plywood by placing one end on the bottom of the tires and raise it up till it stops. You can measure the angle by using a regualar protractor with a string and a washer. Craftsman has a really accurate one that has a magnet on the bottom.
    [​IMG] Sept 1
