ARB for 14bff
Discussion in 'The Garage' started by Mastiff, Feb 1, 2004.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Are they acting like there will ever be an ARB for 14bff?
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Just weld it or spool it.
    Bill
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    spool? I've never seen a 14 bolt spool mini or full available on todays market. In the future yes but not now.
  4. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Uh, yeah Randy's has them... So does Sandy Cone.
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    wow I completely missed them
  6. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    My guess is that by asking about an ARB, welding or a spool is out of the question. /forums/images/graemlins/thinking.gif
  7. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    why not a detroit?? but there isnt an ARB available yet..
  8. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I drive around here on the icy roads in winter and want to keep the road manners as mild as possible. I was contemplating an ARB up front, so why not go all out? /forums/images/graemlins/deal.gif
    The ARB site lists "GM 14 bolt, 9.5" dia. RG, 4800-5700 lb", which I'm not sure what it means. All the rest are semi-float.
  9. heavy4x4
    Aug 28, 2002
    3,270
    The 9.5" is the semi-floating 14 bolt...not what you're looking for.
  10. Confedneck
    Nov 1, 2002
    5,236
    10-4 on the snow manners.. ive only driven in snow once, and if i do it again, it would be too soon.. it actually wasnt bad.. but challenging for a floridian..
  11. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    ARB has been saying for years that it is in development and each time someone contacts them asking, they say it should be out next year. I've been asking for three years now and get the same response each time. I honestly don't believe they are working on it at all, so I gave up and went looking for a rear end that they already made one for (D70). That may not be an option for you though.
  12. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I don't have the 14bff yet, but what I've heard around here makes it seem real promising, like that it can basically bolt in without too many mods. I'm not really set up to cut off and reweld perches, move around shock mounts, etc.
    If money were no object, I'd order a D60 from Dynatrac all set up and ready to go. Unfortunately, I think it'd be pushing $3K for that, so a 14bff from the junkyard sounds pretty nice.
    Since I think I'd like to go ARB someday, I'm trying to find out if the 14b rules that out.
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    I'm looking at an older ad, approximately 2 years, from a magazine and Drivetrain Direct is the advertisee. They have listed and a picture of a 14FF spool for "only $169.95". Their number is 1-888-584-4327. Might be worth checking out. /forums/images/graemlins/thinking.gif
  14. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    To get an ARB in the rear of a GM and have a strong axle I would say find a dana 70 or 60.
    The 14 is not an economical choice for ARB to build. The stock case has been deamed plenty strong by trac-tech (detroit locker). The harcore detroit is $350 give or take and drops in with hand tools (if you have an open carrier). An ARB would run near $900 in part because of the amount of metal needed to keep it stronger than all others, due to the fact that we (CK5'rs) love to try to blow up 14FF as a hobby.
    It is up to you in the end..
  15. skratch
    Oct 28, 2003
    1,646
    Gorveport, OH
    I agree totally. I had a 3/4t 14FF, sold it last night simply because I found a D70HD for a great price.
    I'm not set up to do the mods necessary to swap it in myself, but for the strength and the ability to run the ARB I'm willing to either take it to a shop or over to friends place and have it done.
    If I hadn't found the Dana I was gonna build the 14FF with discs, and a detroit, even though I'm building the rig for snow wheeling.
    If that's what you have in mind, I'd go with the 14 for now but keep your eyes peeled for a 60 or 70 rear. Or it your really lucky and as nuts as I am maybe even a D80 someday /forums/images/graemlins/waytogo.gif
  16. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    What's a good vehicle to find a D70 on?
  17. skratch
    Oct 28, 2003
    1,646
    Gorveport, OH
    Some of the older 1 ton dually's.
    I'd watch out for the chassis cabs because they are narrower. I'm not sure what else to look for them under. The one I'm geting came out of a 4wd tow truck and has a 74" wms to wms which works great with Hummer rims.
  18. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    At least they have a part number listed for them now. /forums/images/graemlins/thumb.gif I got this reply Mid-December last yr.
    Rod,
    Yes, it is part number RD114 and should be available mid-next year.
    Best Regards,
    Tim Lund
    Tech Supervisor
    Engineering Assistant
    Air Locker, Inc.
    206-264-1669
    20 So. Spokane St.
    Seattle, WA 98134
    tlund@arbusa.com<br />
    <hr /></blockquote><font class="post">
  19. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Newer Dodges and some fords have the Dana 70/80 axles. My Inlaws have a D70 under mid thier 90's 350 Ford Van.
  20. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Easiest way is to look at the Fords. LOTS of D70 in them.
    As far as moving the mounts, it will be fairly cheap if you grind the old ones off, figure where you want them put, and clamp them down.
    If you have a welding shop nearby, or a friend in construction or whatever, it shouldn't cost to much at all to have the mounts tacked in, since you have already done all the hard work.
