ARB Question???
Discussion in 'The Garage' started by Supreme70, Mar 21, 2005.
  1. Supreme70
    Supreme70 1/2 ton status
    Jan 19, 2005
    501
    Detroit, Mi
    Does the arb bleed air all the time or just when releasing the lock. I'm wondering if its ok to run a air tank to it and not an air compresser.
  2. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    It should only bleed air when it releases. Air tanks are quite common when running an ARB. Are you going to run a CO2 system? I use the ARB compressor, there is a minimum psi that is required to activate the ARB but I can't remember off the top of my head what it is.......it is a small amount though:o
  3. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    well i can't help you with the ARB. but where are you at in detroit? i'm at vanborn and beechdaly in dearborn heights.i think i've seen your truck.:D
  4. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    if you dont have any air leaks it wont leak.doesnt take much air either. you could probly lock/unlock it all day long w/ a 5 gallon tank @100+psi.
  5. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    in riverview near fort Street and Sibliy rd.
  6. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    It needs very little CFM too. You could probably get away with a 12V plug in $20 emergency pump and a 2 gal tank.
  7. boggerless
    May 26, 2003
    22,728
    96
    cool, lets try and hook up.if you want.it's cool to meet members, plus we have been going to the MOUNDS. i went the first time and now my truck is running so i'll be taking it instead of the DD. PM me if you want to meet.:) daryl
  8. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Ryan B runs his front ARB with an air tank. PM the man himself he'll let you know how it does. If wheeled with him before doesn't look to have a problem at all. :D
