ARB with no compressor?
Discussion in 'The Garage' started by CHEVY 4WD, Mar 30, 2004.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    you could run a ARB with no compressor as long as you kept a small tank on board and filled it up before leaving right?
    Also about how many times can you lock a ARB before the compressor kicks back on?
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Just a guess..
    Your better off using a Powertank or regulated C02, that way you won't run out....I am guessing the compressed air tank won't be ehough...I could be wrong.
  3. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    CO2 works great!
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I run a power tank.
    I also bought an inline constant 80 psi. regulator from mcmaster carr, and put that in right before the arb selenoid.... That way i could accidently bump my power tank regulator up to 120 psi and the constant regulator will always kick it down to 80 psi preventing me from blowing my arb seals. /forums/images/graemlins/thumb.gif
    The only problem with a small tank, it depends on how many times your going to be locking and unlocking your arb.. if you were on a whole weekend trip, i'd say you'd want a powertank then.. It should only be releasing air when you turn off the arb and it goes PSSHHHT.. otherwise it's not consuming any air, just using the 80 psi to hold it locked. /forums/images/graemlins/pimp1.gif
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It's not uncommon for ARB's to leak just slightly. I've been on many trips where someones ARB compressor would be kicking on every few minutes while the diff was locked. (And I've also been on trips where you could hear air escaping from the diff vent line, while the ARB never locked). /forums/images/graemlins/yikes.gif It doesn't take much volume of air to lock an ARB, so with no leaks, and judicious use of the diff-lock button then a 3 gallon or so tank should easily last for a day trip.
  6. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    just currious how much does the entire powertank setup way?
  7. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Does the compressor just INGAGE it then sit, then DISENGAGE it and sit? Like all it does it turn the locker on and off? If so why does everyone upgrade to bigger tanks if all it takes it a little air? thanks
  8. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    It would work OK for a time or 2, but I doubt you would be very happy without a compressor in the long term. My compressor kicks in more often when the ARBs have been on for a short while, but after an hour or so they seem to seal better and compressor stays off for long periods.
  9. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    why do they leak down?
  10. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    So a york compressor or something would work better? I'm planning on getting a ARB eventually so I want to no whats best. I dont no much about air supplies so any help would be great. Thanks /forums/images/graemlins/laugh.gif
  11. Steve_87K5
    May 26, 2000
    521
    central NC
    the air moves a splined assembly in the center of the diff carrier. So the air has to go through a rotary joint. This is formed by an O-ring seal inboard of bearing cap. I think the air pressure being on the O-ring helps to seal it better. The CFM of air that is consumed by leakage is almost nothing, but there has to be sufficient pressure to overcome the return spring, and engage the unit.
