arca 2nd and 3rd place winners
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by drivelineman, Feb 19, 2001.
  1. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    rich hudson took 2nd place at johnson valley and joel randall took 3rd - both guys running my 1350 c/v shafts-
    <A target="_blank" HREF=http://highangledriveline.com>http://highangledriveline.com</A>
  2. CK5
    May 19, 1999
    21,625
    702
    CO
    Cool, can't wait to run your stuff my self. [​IMG]
    Steve
    Mall-Running poseur 4x4 with curb-feelers
  3. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Jesse,
    Just wanted to let you know I got the front 1350 C/V shaft you made for me. That thing is awesome! It bolted right up with no modification to my crossmember, however to get maximum droop I will have to modify the crossmember slightly.
    Thanks again for the quality work.
    DP
  4. drivelineman
    Aug 23, 2000
    707
    hey glad it worked for you daniel- jess-
  5. K5Junkie
    K5Junkie 1/2 ton status
    Mar 29, 2000
    499
    Gulfport, MS
    DP,
    How much lift are you running? I also have the 1350 CV for the front and i cannot even install the shaft without modifiing the crossmember. I am assuming you have the NP241 and 700r4 combo like me. By the way i am runnning 6" lift with Hill4WheelDrive shackles. If you have some pics please post some. Thanks.
    <A target="_blank" HREF=http://k5junkie.coloradok5.com/>http://k5junkie.coloradok5.com/</A>
  6. K5Junkie
    Mar 29, 2000
    499
    Gulfport, MS
    DP,
    How much lift are you running? I also have the 1350 CV for the front and i cannot even install the shaft without modifiing the crossmember[​IMG] . I am assuming you have the NP241 and 700r4 combo like me. By the way i am runnning 6" lift with Hill4WheelDrive shackles. If you have some pics please post some. Thanks.
  7. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    I will try to get some pics tonight. I am running 5.5" BDS springs sitting on a Dana 60 with the ORD Heavy duty shackles. So I ended up with about 7-7.5" of total lift from factory. I do have the 700R4 and a 241. The shaft bolted up with no problems. I have about 4-6" of droop before the C/V will actually touch the crossmember. The only problem I have is I get a vibration at 35mph from the front ujoint being at an angle. I have considered using shims, but do not want to jack my steering up. So I am currently living with it. I usually do not drive 35+ mph in four wheel drive due to having a very aggresive power-lock in the front that does not want to turn.
