Are 2 Cats Emission legal on a 88? WI
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chrome Moly, Oct 6, 2000.
  1. Chrome Moly
    Chrome Moly Registered Member
    59
    Cheesehead Wisconsin
    Greetings smart dudes ! Just wanted to know if I can run 2 cat converters
    on my 88 and still pass thee ole snif test. 88 ,350 ,tbi ,tru duals. I'm Wisconsin! (Gettin ready for hunting.)
    Chrome Moly
    <font color=green>Resistance is Futile</font color=green> [​IMG]
  2. Dave
    Dave Registered Member
    Apr 23, 2000
    63
    Grafton, Wisconsin
    Both my 87 and 90 K-5s pass the good old IM-240 dynos on the factory converter. Actually they both "Fast Pass" (only tested for 30 seconds or so). No reason an 88 with 2 converters won't! I'm just north of Milwaukee....
    Dave Hiller
    90 K-5
    "The Anti-SUV"
    84 K-15
    96 9c1
  3. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
    What county are u guys in? Here in Walworth county we do'nt have emmisions test.... hehehehe :)
    There should be no need to have 2 cats, unless that is how the factory worked it. I suspect you put a dual exhaust on and put a cat on each side, right? If they are new cats, shouldn't be any problem at all.
    Squash
    http://www.trailrunners4x4.org/users/realsquash
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I'm getting my exhaust done today but when I took it in to get an estimate, he said that you cant do it on a 90. This is in Texas, so it'll be different. The only problem I see would be finding a place to put them on.
    90K5
  5. Dave
    Apr 23, 2000
    63
    Grafton, Wisconsin
    I'm in Ozaukee County (next one north of Milwaukee County). I should just register all of my trucks up north :)
    Dave Hiller
    90 K-5
    "The Anti-SUV"
    84 K-15
    96 9c1
  6. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Whether or not you can legally run dual cats depends on what the factory installed. If dual cats were factory-installed, you're OK. If not, then technically you cannot LEGALLY run dual cats. Of course, if you're in a no-emissions-test area (lucky b@st@rds!), or if your buddy is the inspector, then have fun!
    BTW, even if your setup is far cleaner than what the factory installed, it can still be emissions-illegal (no one ever accused Uncle Sam of being sensible...)
    [​IMG] Semper Maintenance!
  7. realsquash
    Jul 12, 2000
    778
    SE WI
    As far as illigality, you cannot modify anything emmisions related, including the PCV valve and other misc. If there isn't any visual inspection, you will get away with the dual cats. WI is not known to be hard-nosed, and I'm not sure if we've got a visual inspections.
    Squash
  8. Dave
    Apr 23, 2000
    63
    Grafton, Wisconsin
    They never do a visual check unless you go for a waiver. They never once (out of the 7 tests one year :P ) put a mirror under my 87 Buick Grand National to see if it had a converter. It did end up passing (he he) in the end.
    Dave Hiller
    90 K-5 87 K-5, 84 K-15, 96 9c1 - Please don't slow down in front of me!
