Are 33's to big for 700r4's??
Discussion in 'The Garage' started by will89, Nov 14, 2002.
  1. will89
    will89 1/2 ton status
    Oct 21, 2002
    104
    nomad
    Are 33\'s to big for 700r4\'s??
    Im not doing any hardcore wheeling but are 33's too much strain for this tranny as a daily driver on stock 1/2 ton with the 10 bolt diff?
  2. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Re: Are 33\'s to big for 700r4\'s??
    Depends on the gear ratio in your axles.
  3. will89
    Oct 21, 2002
    104
    nomad
    they are stock..but I don't know what that is off hand.
    89 1/2 ton Sub
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    no, but you have to build your rig right.
    The ORD jimmy has a 700 with 42" tires and 500ft/pds. of torque coming from the 468 BBC.
    gearing has to be considered, as well as a tranny cooler.
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Your '89 Sub probably has 3.42 gears. 33s are fine with that set-up, but don't drive in O/D except over 65 mph on the highway. Use D at all other times and the tranny will be fine.
  6. will89
    Oct 21, 2002
    104
    nomad
    Bought it used and I know it was rebuilt once but Im not sure to what specs. The guy who had it did some towing but im pretty sure its all stock..
  7. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    I run mine all the time with OD and 35s with 3.42s, but i watch the Trany temp and have a Big @$$ cooler.
  8. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    I ran 33's with 3.73 10bolts for over a year and never had a problem. Now running the same tranny with 4.56's and 37's still smooth sailing /forums/images/graemlins/cool.gif You'll be fine /forums/images/graemlins/pimp1.gif
  9. will89
    Oct 21, 2002
    104
    nomad
    I was thinking of putting a temp gauge in... Where do you mount it in the pan to get an accurate reading. If its by the return line from the cooler it will read low etc....
    Where did you put it?
  10. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    i put a it in a drain plug in the pan.
  11. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Depends on how it had been maintained over its life. A lot of 700R4's go out at about 100K if they aren't really taken care of, I know mine idd, but this was before I owned it. With 33's 3.73's or 4.11's would be a lot better for it, mine died twice with 33's. Also the quality of your rebuild is important. Mine was rebuilt at a bad shop the first time, maintained perfectly by the second and third (me) owners, and crapped out again after 50K miles. If you run at least 3.73's or drive in D instead of OD all the time, keep it cool and dont do anything stupid it should last a while.
