are 35's gonna be OK?
Discussion in 'The Garage' started by suthrnchvyguy89, Oct 10, 2004.
  1. suthrnchvyguy89
    suthrnchvyguy89 Registered Member
    Oct 10, 2004
    51
    charleston, sc
    are 35\'s gonna be OK?
    i have an '89 k5 /forums/images/graemlins/k5.gif with a 4" suspension lift and 33" tires right now and i need to know what i would need to upgrade up to some 35's. /forums/images/graemlins/1zhelp.gif i heard id probably have to do a 1" body lift and upgrade the brakes. is that is or is there sumthin else i should know about? any help would be appreciated thanks
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Re: are 35\'s gonna be OK?
    yeh on my truck since i didnt want to cut my primo fenders, i had to do a 2" body lift. Of course I have 14.5" wide tires, dont know how wide you are goin. Brakes, I didnt look at your profile and see if you still have 1/2ton axles, if so, and you plan on keepin em, theres a few places that sell different rotors, hi-po pads etc. If you plan on a 3/4 or 1ton swap, you will get the bigger brakes in that swap, so if it was me (and i planned on 3/4 or 1ton in the somewhat near future)I would save the brake $$ on the 1/2ton stuff and wait for 3/4 or 1ton brakes w/ new axles.
  3. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    It all depends on how wide your tires are, how wide the rims are, and what backspacing you have. I run Q78's on 5.5" wide rims with about 4" backspacing. When i first mounted them they measured 36.25x10.5". I run a 2" BL, and thats it. No trimming, no suspension lift. heres a pic:
    Tires dont rub anywhere but the pitman arm.
    EDIT: missed your brake question. With the heavy Q's on, i can still lock up the tires. I think the truck stops better with the Q's than my radial BFG's.
  4. suthrnchvyguy89
    Oct 10, 2004
    51
    charleston, sc
    im not sure what type axle i have because im new to the whole off road life style, but i do know the the front ones differential is off to one side it says 1500 on the side of it in the molding
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    6 or 8 lug?
  6. suthrnchvyguy89
    Oct 10, 2004
    51
    charleston, sc
    6 lug
  7. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    35's should work great with what you have (I wouldn't go any bigger, though). You have 10 bolt corporate axles (Front & rear). I wouldn't put any money into them, because they are just about good enough to get from point a to b, and back. Welcome to the board!
  8. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    /forums/images/graemlins/eek.gif
    Yes I am mentally defishnet.
  9. jwduke
    Aug 25, 2001
    721
    HUH??
  10. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Right at this minute my K5 is sitting on 36's with a 5yr old flattened out 4" lift. I cut some of the fenders, wish I wouldn't have now. Never had a rubbing issue.
    You should be fine, but like said earlier depends on the width size of tire, rims, and back spacing.
  11. 4GUNZ4X4Z
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Oh and the brakes aren't an issue.
  12. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    I run 35X14's no lift mild trim &hammer on front fenders no problem /forums/images/graemlins/thumb.gif
  13. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    I have a 1973 Chevy Pick-up with a 4" lift and 35" tires. No problems so far! /forums/images/graemlins/waytogo.gif
    /forums/images/graemlins/peace.gif
  14. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    666
  15. jwduke
    Aug 25, 2001
    721
    Oh, ok /forums/images/graemlins/confused.gif
