Are 6 inch springs much stiffer than 4 inch?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigk, Nov 23, 2001.
  1. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    Just curious about your experiences. I want a good ride that I can enjoy driving around with, but don't know if I should combine a body lift with a 4 incher or just go 6 inch. Fender trimming doesn't bother me at all. Eventually want to run 38 inch tires.
    Karl
    Temporarily Unemployed Underwear Model
    87 3/4 ton
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    Its entirely possible to run a 4" lift with 39.5s and no body lift at all...if you do serious fender trimming, there was a guy in a recent 4-wheelin mag that had just that setup.
    Personally, I like the idea of using a standard 4" suspension lift...combined with ORD 1" add a leafs and shackle flip (ORD or home-brew, up 2 u)....and then just trimming the body back as-needed to run whatever tires ya want. A set of ORD HD shackles for the front will give ya another 0.25-0.5" as well. =p
    J
    See the on-going build up of my '85 Jimmy! http://community.webshots.com/user/jekbrown
  3. big75jimmy
    big75jimmy Registered Member
    Jun 26, 2001
    77
    Kirksville MO
    I would go 4 in suspension,3 in. body lift. With the 4in. you wont have to modify as much than with the 6 in.
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I have a 6" BDS lift and it rides AWSOME!!! But they are right in saying you will needs some mods... pitman arm, longer brake lines are a must, drivetrain angles get a lot harder, etc.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
