Are 'Add-a-Leafs' + 'HD Front Shackles' ok for a 2.5" Front Lift?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stoopalini, Jan 8, 2001.
  1. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Are \'Add-a-Leafs\' + \'HD Front Shackles\' ok for a 2.5\" Front Lift?
    I'm pretty set on the 2 1/2" shackle flip for the rear and am debating on what to do with the front.
    Should I get lift springs; or will Hill's Extended front shackle + ORD's 1" add-a-leaf be ok to lift the front? It's my understanding that lift springs will ride a lot harder then factory, so I would like to keep the factory ones if I can.
    With this setup, I should get 2 1/2" in the rear and apx 2 1/4" in the front. My truck sits level now and is stock, so this should be good, right?
    Thomas.
    -- '84 K5 Blazer --
    <A target="_blank" HREF=http://Stoopalini.coloradok5.com>http://Stoopalini.coloradok5.com</A>
  2. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Re: Are \'Add-a-Leafs\' + \'HD Front Shackles\' ok for a 2.5\" Front Lift?
    Come on guys, someone has to have an opinion on this. I appreciate any and all thoughts on this setup.
    I finally got the cash together to get this all done, and have to make purchasing decisions now.
    Thomas.
    -- '84 K5 Blazer --
  3. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Hey dude,
    Personally I would not go with the extedned shackles unless you plan on using shims to correct the negative camber the shackles will create. I would also be concerned about using a block in the front. Even though it is only an inch and is in the spring pack. I would go with a set of springs. You can get a set that will be close to the factory softness.
    Daniel
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,068
    479
    Grand Rapids area
    Are you sure that 2.5" is all you want long term?
    I don't think that the 1" add-a-block is recommended for the front. If you want 2.5" springs, your choice of brands will be limited. You could use the shackles with a shim for 1" in the front and then have the factory springs rearched for another 1.5" This would be another inexpensive route and would only add a little stiffness. I have been kicking around an idea to make a custom leaf pack using the top leaf from the existing front pack and combine it with 2 or 3 leafs from a set of late 80's stock rear K-5 springs. It would be flexy and cheap, but it might require a bit of trial and error to get it right.
    I definately recommend a shackle flip in the rear over a block. Be aware that there is no way that a shackle flip won't affect your pinion angle, so be prepared to put in a shim or something.
    <font color=blue>Powered by a Goodwrench 4-bolt longblock [​IMG]
    240hp...for now.</font color=blue>
  5. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Cool! Thanks guys.
    I guess the 2" EZ Ride Lift Spring coupled with ORD's HD Front Shackle will work. This will give me the 2 1/2" I'm looking for.
    2 1/2" is all I want for a suspension lift. When I'm done here, I should be able to put 33's on there with no problem. Then in the future, I could do a 2" body lift and throw 35's under it .......... I dunno, we'll see.
    Also, with only 2 1/2" suspension lift, I shouldn't have to do too many other mods ......... like Steering arm, Drive Shaft lengthening, etc ...... might have to shim the X-Fer case? but maybe not.
    Thomas
    -- '84 K5 Blazer --
  6. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Now your thinking better, please don't try to get 2 1/2" suspension lift in the front with shackel extenders and a 1"
    block(even the one inch ORD zero-rate leaf), it can be done, but in your case I would not reccomend it.
    In you case get some new leaf spring up front, this I reccomend.
    Happy hunting for the right spreings up front, they are out there you havr to find them.
    Good luck
