Are all 10 bolts made by GM? Heard some conflicting info,,,
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nrose07, May 13, 2002.
  1. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    Was talking to a used 4x4 parts yard guy and he was telling me that 3/4 (8 lug) 10 bolt frond ends are not corprate axles. He told me that they were built by Spicer. And that the quality and strength is better.???????????????????? Anyone got info on this???
  2. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    I'm pretty sure the Dana (spicer) 44 has 10 bolts.
  3. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    yeah, homey at the junk yard is trippin'. He must have got confused by both the 10bolt and d44 having 10 bolts that hold the cover on. The d44 (that he thinks is a 10bolt) is a hair stronger because it has 30 spline axles as apposed to the corp.10bolt having 28 splines (unless it is 88? or later, then it will have 30 splines too)
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I don't know about 10B's but the 3/4-ton D44 has a thicker center section than the 1/2-ton D44. It is about 1/2" thicker where the pasanger side axle tube goes in.
  5. Nrose07
    Mar 29, 2000
    267
    Salem ,Or
    Well thanks for the info, thats what I always had thought. He seemed pretty sure of himself so I thought I'd ask. Thanks guys!
  6. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Although the 30 spline axles neck down, negating the extra strength of the thicker axle. An axle is only as strong as it's weakest point.
  7. Grim-Reaper
    7,385
    Atlanta
    10 Bolt fronts are made under contract to GM spec by Spicer. Most even have a Dana <> in the pumpkin casting. The knuckles out are interchangable.The 10bolt has thinner tube walls than the D44. 3/4 10 bolt may have thick wall. ALL the seals including the inner axle shaft seals are the same.
  8. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    the 10 bolt has thinner tube walls, but a greater tubing diameter.
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I thought they were American Axle product like the 14s and the new 11" and the new dodge difs
  10. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    This does not make sense !
    Please post an verifiable source.
  11. Nrose07
    Mar 29, 2000
    267
    Salem ,Or
    OK now this is more inline with what the guy was telling me. He said the 3/4 were made by Dana/Spicer and the regular 1/2 were GM. I realize the differences like everyone else between D44 and 10b, 12b,14b. But I haven't ever seen the real specs between the 1/2 and 3/4 10 bolts. Fact please, not fiction.
