ARE ALL 4x4 TH350's the same length ? Read to the bottom.
Discussion in 'The Garage' started by ColAdo82K5, Jun 10, 2004.
  1. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    ARE ALL 4x4 TH350\'s the same length ? Read to the bottom.
    Hey,
    Just got the 350 back together not to long ago and I'm happy with added power, but I fear that that something in my tranny (TH350) didn't like it.
    I went out to drive it and when ever the truck is sitting still but with the tranny in drive or reverse, there is a continous noise like sandpaper rubbing it self. As you give the truck a little bit a of gas, it sounds like the fins in the convertor are slipping alot. Once you get the RPMS up to about 1900 or 2000, the noise and the slipping stops and the truck drives like normal. I know the fluid level is good and the filter and fluid should be ok. To me it sounds like something in the convertor is wack...
    Help me out here guys...
    Blake
  2. dyeager535
    26,979
    Re: IS MY TORQUE CONVERTER BUSTED ? HELP
    The converter is mechanical. If it fails, you'll know it. Only thing that can go wrong (essentially) is a fin comes off, some teeth strip, or the thrust washer or bearing fails.
    If your converter truly fails, your auto tranny vehicle will not move AT ALL. (such as if the splines strip) However, if the thrust washer or bushing fails, typically the sound goes away when put in gear, but is present when in neutral/park.
    There are quite a few things turning in an auto transmission even when it is sitting still, so there are a LOT of variables. Could very well be the pump is galling the housing, and you are getting a lot of pressure "loss" around the pump teeth.
  3. ColAdo82K5
    Feb 18, 2000
    789
    MO
    Well,
    I gave a quick call to the transmission shop and they said not to look at the convertor either...so it looks like I will have to swap in a new one or get this one rebuilt.
    Any other thoughts ?
    Blake
  4. dyeager535
    26,979
    Not many. If it's making noise, it needs to be pulled apart. TH350 isn't a bad tranny to try a rebuild on yourself though.
  5. ColAdo82K5
    Feb 18, 2000
    789
    MO
    I imagine that the trust washers and bearing can't be changed out or checked unless the valve body is taken out. and the main shafts are taken out. Correct ?
    I've helped with a shift kit on one of these before, but never rebuilt a tranny on my own. I'd rather not rebuild that one and put it in because I'm on a time limit. Hopefully I can get one locally and slide that in. (Maybe rebuild the original one for something else)
    Thanks,
    Blake
  6. ColAdo82K5
    Feb 18, 2000
    789
    MO
    Hey,
    I'm in the middle of finding the tranny jack and a tranmission to go in the truck.
    Are all th350's the same spline/length ? The changing part all takes place in the adaptor, right ? Say, a th350 that is hooked up to a 203 right now with work with my 208, because I'm using the 350-208 adaptor.
    Blake
  7. dyeager535
    26,979
    Thrust washer/bushing I'm talking about was the torque converter. But anywhere else in the tranny they exist, yes it has to come apart.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    All TH 350s are the same spline, but no, they're not all the same length. I'm not sure how many variants of 4wd units there happen to be though.
  9. ColAdo82K5
    Feb 18, 2000
    789
    MO
    Why do you say there are variants ? Don't the adaptors make up any length differences ?
    Blake
  10. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the only difference in length is the output shaft, they are all the same spline though. the 203 is the shortest shaft, the 205 is the next shortest and the 208 is the longest. you will need to have the correct shaft put in when you have it rebuilt. best thing to do is have your tranny rebuilt or find a th350 with a 208 and rebuild that.
  11. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    203 and 205 use the same output shaft in a TH350.
  12. ColAdo82K5
    Feb 18, 2000
    789
    MO
    So, we have a 203/205 version th350 and a 208 version th350.
    Thanks guys.
    I'm having a friendly shop here take my parts and my tranny to rebuild for $100 cash. I work at Autozone, so I'm supplying the rebuild kit and they are getting me a new convertor for $55.
    Blake
  13. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i though they were a little different, but i never seen them sitting side by side /forums/images/graemlins/thinking.gif /forums/images/graemlins/doah.gif
