are all 700R4s overdrive
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ditchdigger, Mar 11, 2001.
  1. Ditchdigger
    Ditchdigger Registered Member
    Mar 11, 2001
    96
    The Great Midwest
    I have an 84 K-5 with a 305ci Q-jet
    and wandering if all 700R4s have OD
    and I am also wandering what rear end gears I
    have, it has 10 bolt diffs front and rear
    If it ain't intimidating / It ain't a Chevy!
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Yes all 700's are overdrive. Look inside your glove compartment and look at the codes in there, it should tell what gears you have but I dont know what the individual codes mean(I'm sure someone else does), there also may be a sticker on the inner fender that tells you. Or you could pull the cover and use this formula:
    Ring Gear Teeth Count / Pinion Gear Teeth = Gear Ratio
    Murphy's Laws on Life :
    "Opportunity always knocks at the least opportune time." [​IMG]
  3. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    The codes for rear gears in the glove box are as follows. GU2 = 2.73 GU4 = 3.08 GU6 = 3.42 GT4 = 3.73 GT5 or GT8 = 4.10 and G80 = gov. lock I just did this because I wanted to know what my rear gears were.
    Ben 87 Jimmy
    "if it ain't got rust, it ain't got character."
  4. Chewy
    Chewy 1/2 ton status
    Sep 4, 2000
    197
    Parker, Colorado, USA
    You could also check out the specifications page for info.
    '87 Beast
    Colorado, USA
