Are all Dana 60 covers the same?
Discussion in 'The Garage' started by RingMaster4x4, Feb 11, 2005.
  1. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I have been looking at Dana 60 covers and I keep finding the one I am looking for in a Ford and Dodge Dana 60 applaction. I was just wanting to know if the one for a ford or dodge would bolt on to a chevy D60?:confused: TIA
  2. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Yes they will all bolt up but technically there are differences in both thickness and shape.
    I don't know all of the thick applications but it seems that the OE covers for the Chevy front covers are always the thicker ones. The shape differences are around the filler plug (I believe the difference is in front vs rear applications).
    Also, beware that for the finned aluminum covers there are different ones for front and rear to avoid tie rod interference. (tie rod interference is not an issue for the steel covers)
  3. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    OK so as long as it is for the front. I should be OK? I have a Rock Rod on the K5 too if that makes a diff. I am looking at the finned ones just a little pretty for the old blazer.:D
  4. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
  5. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
  6. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    ....bling....
    That is nice, I just cringe when I think about what would happen to that on my truck.... :blush::D
    Seal the gasket to the cover, grease the other side of the gasket for ease of removal and sealing (if you feel you will pull the cover someday). My tech-tip of the day (weak :p:).
  7. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    If I did rock I would have a pair of these.
    But I do mud mostly, and a little Mall Crusing.:grin:
  8. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
