Are all Dana 60 outer knuckles the same?
Discussion in 'The Garage' started by Flexy K20, Feb 28, 2003.
  1. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    I was curious if all Dana 60 outer knuckles are the same. Because most of all the aftermarket highsteer arms are
    same. But I know the bolt patten on the top of the knuckles (4 bolts) is different, because you cant swap the
    top cap and steering arm from one side to the other. The holes dont line up. Is this how they all are? What do you
    do when you order arms if they are different? Thanks
    -fLeXy K20
  2. NoRulz
    NoRulz 1/2 ton status
    Feb 6, 2001
    388
    Mesa, AZ
    the 4 bolt patteren isn't the same? That's news to me, I've had my hi-steer arms swapped back & forth side to side many times. They swap between GM, Dodge, & Ford with no problems to my knowledge...
    Anyway, check out this thread, lots of info in there if ya read through the whole thing.
    http://www.pirate4x4.com/forum/showthread.php?s=&threadid=112355
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    The four bolt pattern is the same left and right.
    -- Mike
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    I bought a crossover arm from ORD and it fit the passenger side no problem and also the cap from the passenger side is now on the driver side. /forums/images/graemlins/confused.gif
  5. Flexy K20
    Oct 22, 2002
    398
    Bay Area, CA
    Alright well if you all say so. I go check again and let you know. Later
    -fLeXy K20
  6. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yep same here, cap from pass side is now on my drivers side and the ORD steering arm is on the pass. side of my Ford Dana 60... Don't know what you been smokin /forums/images/graemlins/rotfl.gif /forums/images/graemlins/grin.gif
  7. Flexy K20
    Oct 22, 2002
    398
    Bay Area, CA
    I dunno either, I checked last night and I guess they are the same. /forums/images/graemlins/blush.gif Later
    -fLeXy K20
