Are all TH350s the same?
Discussion in 'The Garage' started by meanboyjr, Apr 25, 2006.
  1. meanboyjr
    meanboyjr 1/2 ton status
    Nov 28, 2005
    350
    South Sound, WA
    Here's the scoop: I bought a '76 K5 with the 350/TH350/NP203 combo a few months ago for cheap, mainly because I've always wanted one. The truck needs work, but it was complete driver, with just a little rust in the rockers. Anyway, a few weeks ago the trans started slipping and now I only have 1st and 2nd gear, with Park...no 3rd and no Reverse.
    Not a big deal, I thought, since I have a junker '81 GMC G20 (3/4 ton) van with the 350/350 combo in it. I'll just "drop and swap" the trannies, right? I've got one sitting there, so why not use it? It's free...
    Never having done this before, I searched the forums and learned a lot of good stuff, but I couldn't find the exact answer I was looking for - will ANY TH350 swap for ANY other TH350, regardless of the year and application?
    I know I'll need a transmission jack to get the heavy stuff back into place, but are there any other tips on making this job easier & smoother? Other than bringing it to a shop? :wink1:
    On a related note, I like the NP203 just fine, but I've been thinking of adding a MileMarker P/T kit while the tranny and transfer case are already out. Any input? Should I leave it full time or not? I'm not planning on doing any serious wheeling, and it won't be a DD - mainly a weekend use, FS road, hunting/fishing/camping rig with the occasional trip down to the Oregon coast. Will the P/T kit allow for slightly better gas mileage?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    as long as the newer 350 tranny is not the 350C which has lock up it will work with no problem. also the van has a two wheel drive tranny so you would have to change the output shaft
  3. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    cant use the van one in a 4x4
    have to have the tailshaft swapped
    trade it for a 4x4 one or have it converted
    4x4 ones have no tailshaft housing
    and have very short tail shaft
    unlike 2wd ones
    in which there were three different lengths of
    good luck
  4. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Non-lockup TH350C here, from a 1973 Carlo. And yes I did the shaft conversion:hack:
  5. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    The part time kit will make the truck easier to turn in slow corners, but you won't see a lot of improvement in gas mileage.
  6. meanboyjr
    Nov 28, 2005
    350
    South Sound, WA
    Thanks for the info, fellas.
    Roadnotca - are you running the TH350C without the lockup plugged in?
    Also, I'm guessing I can swap the output shaft from the tranny that's already in the Blazer...
  7. dyeager535
    26,979
    TH350C *is* lockup, TH350 is not. Can't recall when they came out with the TH350C, either late 70's or early 80's, but not '73.
    They don't seem to have a problem being run without lockup (unlike some of the 700's) but I'd be looking for additional cooling either way.
    The converter is not interchangeable between a TH350 and -C, so something else to consider.
  8. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    8 hrs. until I can check my info. :haha:
  9. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    ttt
  10. dyeager535
    26,979
    http://www.drivetrain.com/transautogmapp.html
    Maybe that will save you the hassle. They show the years there.
    Not that internet info is always right, but since the TH350C was only used in a few years of the C/K trucks, I will *guarantee* that it wasn't used as early as 1973. :)
    Don't be confused by the various early 70's (and up) emissions/spark control variants out there that will also have electrical plugs on them.
  11. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Like I say, it'll be 8 hrs. until I can check it out. My tranny is totally hydraulic, no electrics. :D
  12. meanboyjr
    Nov 28, 2005
    350
    South Sound, WA
    Thanks Dorian. I did check that website http://www.drivetrain.com/autotranscrossref.html previously and they called out the TH350C for my '81 GMC van (the tranny donor). According to just about everything I've been able to find, the location of the lockup harness/plug-in is right where it should be, so I'm guessing it is indeed a TH350C. Without pulling it and taking a look at the torque converter, I won't be able to tell for sure, but by then...well, I might as well just have found the correct rebuilt tranny somewhere and slapped it in.
    All this effort just to save a couple o' bucks! :)
  13. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Ah, my book says mine's a TH350.:crazy: I still need to crawl under to look at fitting the aluminum TC-cover, I'll check markings then.:confused:
